390 with single plane needs more torque.. dual plane???
#150804
11/14/08 12:28 PM
11/14/08 12:28 PM
Posts: 1,586 Tampa, FL
tpabayflyer
Tampa, FL
While my 83 Cordoba 390 stroker project is down waiting for the new trans to be built I was wondering how I can get more low end torque. My combo is not very radical as it is a street/strip car that will be used alot on the street. I am using a Torker 2 single plane intake that is really excellent above 3,500rpm. It really pulls great in the upper rpm range but I would like to get some more low end ooomph. Here is my combo 70 318 block 4" crank KB forged pistons,9.7 C/R .044 quench Iron EQ magnum heads with 2.02 intakes fully ported Cam is Comp HE-275HL series 231/237 duration @.050 .565 lift Hooker super comp headers 1 3/4 with 3" exhaust and X-pipe Holley 3310 750 vac secondary carb 3.73 gear 8 3/4 rear that has the 2.74 low gear A-999 trans My limitations are the 2,600rpm stall converter that I just can't change. A higher stall will cost me over $600 and that is just not in the budget right now. I know that would solve my problem but I can't do it now. Aside from that, what is the best way to get some low end back?????? I do not have the vacuum advance hooked up now and will that help me out to get the distributor dialed in properly? I have a 74 electronic dist with an MSD 6al box and blaster 2 coil. I also bought the secondary spring kit and have a very light spring in now. In fact when cracking the throttle, the secondaries start to open up so maybe I have too light a spring in there now. Question, will a nice dual plane like the Edelbrock rpm air gap be a better combo for me considering the mods I have right now??? That was my original plan but I am using the stock A/C compressor and the Torker 2 and the standard performer intake are the only 2 that will fit. ( Or a stock iron intake ) However, I have researched and found a way to modify the existing AC brackets to move the compressor over about 2 inches to get the cleance needed for the water pump outlet. I can also get the Bouchillion kit that does the same thing using a short A/C compressor and it will cost me $400. Unfortunately, I just spent $250 on a new, stock C171 compressor that I want to keep as it works great. I can sell my Torker 2 to help offset the cost of the new intake and that will be the best solution for now as far as I can see. Can I tune this 390 better for more low end using the single plane or am i wasting my time and just get the air gap now???? Thanks TBF
71 Challenger 528 Hemi project 09 Gr Cherokee 5.7 hemi in da house!!
Re: 390 with single plane needs more torque.. dual plane???
[Re: tpabayflyer]
#150805
11/14/08 12:37 PM
11/14/08 12:37 PM
Posts: 3,325 Truckville, the capital of NY
85_Ram_4speed
You have a 4" stroker motor and you want more torque?
I say a performer RPM will get you what you want.
Also, what kind of timing are you running? I personally would start out with 15 degrees initial, but of course the slots in the distrib rotor plate need to be welded up some first to do that so the total timng doesnt get past 34ish degrees.
Outcast Dodge guy.
[Re: tpabayflyer]
#150806
11/14/08 12:40 PM
11/14/08 12:40 PM
Posts: 10,968 Hampton, Ga.
70dart360
Green Meister
Green Meister
Hampton, Ga.
A dual plane will definitly help. An air gap will improve it across the board too IMO. I put a regular performer back on my 360 with Eddy heads when I put it together, just cause I had it and ran out of $. The bottom end was like but the rpm range endedbout 5000. Put an air gap on it and the bottom end was still very strong, and the rpm range went way above 6000 easy. Made 412 hp at the back wheels at right at 7000 rpms.
70 Dart Swinger
72 D-100 440 shortbed
76 Pinto, 68k 21mpg!
[Re: tpabayflyer]
#150807
11/14/08 12:46 PM
11/14/08 12:46 PM
Posts: 196 West Central Indiana
Mr.Runum
How is your cam installed? straight up, advanced? Advancing the cam will help and not a lot of $$. I personally like daul plane intakes. Every motor to leave the factory is a daul plane. Hemi, Six Pack, Big Chev, Fords. Big and Small block and they all ran like a scalded dog. For just straight line Single is fine but on the street. look at your rpms most of the time, will be down low. So, cam advance, timing, carb adjustment (secondaries) Mr.Runum
69 RoadRunner 383 4spd coupe, 06 Hemi Daytona Charger, 08 6.7 RAM QC short bed 3/4 4X4
[Re: 70dart360]
#150808
11/14/08 12:49 PM
11/14/08 12:49 PM
RapidRobert
tighten up the secondaries & play with your timing & get the timing right & the vac adv can be added later.
[Re: RapidRobert]
#150809
11/14/08 01:09 PM
11/14/08 01:09 PM
Posts: 11,711 Portage,michigan
B3422W5
Portage,michigan
Three fixes.
1. Convertor 2.Compression 3.gear
anything else you are chasing your tail
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: RapidRobert]
#150812
11/14/08 01:27 PM
11/14/08 01:27 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
You know the secondaries are not right. They should not crack open ever unless you're in gear and accelerating. I would put the plain spring back in as a good starting point. NExt, you know the ignition isnt set up right. Get acurve in the distributor, and hook up the vacuum advance. You need to get what you have working, before you dump more money on parts. I don't think, afte these changes, that you will need any torque boost.
[Re: B3422W5]
#150814
11/14/08 01:51 PM
11/14/08 01:51 PM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
comntact board member calgecko, I gave him plans to produce some adapter brackets I designed to run an air gap on my '86 5th ave while retaining the C171 compressor.
the RPM/air gap will definitely add some bottom end
another option would be advancing your cam with an offset cam key 2-4 degrees....just be sure to check valve to piston clearance.
I'd get your carb/ignition dialed in first before tearing into the motor though.
what pistons are you using?
[Re: moper]
#150817
11/14/08 02:19 PM
11/14/08 02:19 PM
Posts: 576 Escondido, CA
kick_the_reverb
Escondido, CA
That's the best advice you got on this thread. Ran
"Hey mister, something's wrong with your car, it idles roughly" - number one comment I got in Israel when daily driving a 70 Barracuda with a lopey cam.
Currently working on - 1966 Dodge A100 van 318/auto Finally - disc brakes on the front. In the plans - rear disc brakes, B&M 250 blower
[Re: tpabayflyer]
#150822
11/15/08 10:04 AM
11/15/08 10:04 AM
Posts: 9,875 Weddington, N.C.
Streetwize
Weddington, N.C.
I agree try a stiffer spring first and go ahaed and do the quick change diapragm conversion and a rear metering block kit too....just gives you a ton more tunability.
I'd prefer an RPM or an AIR GAP (I've never really seen an air gap make any more noticable power than the regular RPM btw....you still have water passing through the manifold) and block off one side of the heat riser (so it still works but doesn't cross contaminate the cylinders).
My old 383 750 combo was like a 72/76 jet, 6.5 primary valve, a 31 rifle shooter, pink cam in the #2 position and I think I ran the long purple spring. Don't worry about fine-tuning the spring until you get the timing and primary jetting right, just see if delatying it with the stiff black sring helps...then you know you're onthe right track and maybe don't need a manifold.....and if you're distributor isn't recurved for a stroker you're leaving power on the table, send it to Don at FBO with all your specs but I would estimate you want a mechanical conversion with about ~18 degrees initial with a 4" stroke and a decent size cam, and then a relatively slow curve to 34-36 maybe all in by 2800 or so....it's nice if you can run at or near full advance at highway speeds but that may not work in a cordoba body which is pretty heavy (I had a 77 Charger for a time so I know).
