Main bearing & rod bearing journal clearances for 440.. #150800
11/14/08 12:19 PM
11/14/08 12:19 PM
Wichita,KS
Blakcharger440 Offline OP
Wichita,KS
I am getting ready to use some plastigauge in determining how much clearance I have at the main and rod journals.
What parameter of clearance would be good for the mains and what would be good for the rods?
These should always be checked dry correct?
This is for a standard bearing size 4.25 stroke RB crank
Re: Main bearing & rod bearing journal clearances for 4 [Re: Blakcharger440] #150801
11/14/08 12:21 PM
11/14/08 12:21 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
We never to go over .002 on either the rods or mains. Never had a problem with those clearances on the engines we run on the street or strip.
Re: Main bearing & rod bearing journal clearances for 440.. [Re: Blakcharger440] #150802
11/14/08 12:34 PM
11/14/08 12:34 PM
yes both bearing halves/journal dry & be careful when you set the crank down that you dont rotate it & I always grab a helper to eyeball things underneath so the crank goes down where it's supposed to & doesn't get nicked.
Re: Main bearing & rod bearing journal clearances for 440.. [Re: RapidRobert] #150803
11/14/08 01:28 PM
11/14/08 01:28 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
.002-.0025 on mains, .0025-.003 on rods. I have gone tighter before... I never go bigger.
