66 Belvedere II - Oil Filter #1507887
09/26/13 01:12 PM
09/26/13 01:12 PM
Northeast
edl Offline OP
edl  Offline OP
Northeast
426 ci engine - just removed the filter PN P4529805 - it has been discontinued - what is the replacement part number? - thanks!!
Re: 66 Belvedere II - Oil Filter [Re: edl] #1507888
09/26/13 06:48 PM
09/26/13 06:48 PM
Northeast
edl Offline OP
edl  Offline OP
Northeast
for those that may want to know, it crosses over to anything ending in an "8A" in FRAM
Re: 66 Belvedere II - Oil Filter [Re: edl] #1507889
09/26/13 06:50 PM
09/26/13 06:50 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
You don't want to put a fram on anything you have respect for.
Are you stuck on only a not stock looking Mopar filter ?
Re: 66 Belvedere II - Oil Filter [Re: JohnRR] #1507890
09/26/13 06:59 PM
09/26/13 06:59 PM
Northeast
edl Offline OP
edl  Offline OP
Northeast
i didn't go with the fram - just now know that is what it crosses to - i went with a hastings filter - but i can't tell you which one it was - - the one i took off the car had a "copyright 1970" sign on it...so assume it was a nos piece - no idea where to get something like that - the hastings will work for now until i can figure out the right thing to get!
Re: 66 Belvedere II - Oil Filter [Re: JohnRR] #1507891
09/26/13 07:00 PM
09/26/13 07:00 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
If you like your motor DO NOT use Fram filters. They are inferior at best.
Re: 66 Belvedere II - Oil Filter [Re: stumpy] #1507892
09/26/13 07:03 PM
09/26/13 07:03 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Thats an understatement !!!
I am truckless..
Re: 66 Belvedere II - Oil Filter [Re: stumpy] #1507893
09/26/13 07:03 PM
09/26/13 07:03 PM
Northeast
edl Offline OP
edl  Offline OP
Northeast
yep ... did NOT go with the FRAM ... went with something called Hastings (which i actually have never heard of) - will upgrade once i can figure out if there are still nos filters around...
Re: 66 Belvedere II - Oil Filter [Re: edl] #1507894
09/26/13 07:05 PM
09/26/13 07:05 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Unless you are totally anal about original numbers, but you can't be considering you have an electric fuel pump, any good (non fram) filter will be fine. Hastings has been around for longer than your car has. They have a good rep.
Re: 66 Belvedere II - Oil Filter [Re: edl] #1507895
09/26/13 07:11 PM
09/26/13 07:11 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
It might have been NOS , but with this part number PN P4529805 , it was NOS from the 90's ....
Re: 66 Belvedere II - Oil Filter [Re: JohnRR] #1507896
09/26/13 10:38 PM
09/26/13 10:38 PM
Northeast
edl Offline OP
edl  Offline OP
Northeast
thanks for all the input guys - much appreciated - stumpy, didn't know that brand has been around that long...good to know!
Re: 66 Belvedere II - Oil Filter [Re: stumpy] #1507897
09/26/13 10:42 PM
09/26/13 10:42 PM
Northeast
edl Offline OP
edl  Offline OP
Northeast
on the original numbers thing, i am trying to keep it as original as i can - so taking the electric fuel pump as an example, that is the way the car came - if it weren't there, i wouldn't have added it - but i am not racing to undo do it and put it back to bone stock - little, by little - on the brakes, i just rebuilt them and keep them drums all the way around just the way they came - with the master cylinder, i put the the 67 mc in because it is 2 stage and so for safety if i lose one set of brakes i have the other - that is kind of the philosophy - in terms of what i got, the car is pretty much stock (but with the odd exception (like the fuel pump))
Re: 66 Belvedere II - Oil Filter [Re: edl] #1507898
09/27/13 02:28 AM
09/27/13 02:28 AM
State of Fascism
52savoy Offline
52savoy  Offline
State of Fascism
Chrysler sells replacement filters(or was) a couple years ago with a 34XXXXX pn
I bought a case or two. They are gray in color.. If your interested in one let me know(pm)..
Fred
Re: 66 Belvedere II - Oil Filter [Re: edl] #1507899
09/27/13 08:53 AM
09/27/13 08:53 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
You aren't going to find an original filter unless you look on places like ebay , there you may run across a 40 yr old filter for $1500,. Me , the last thing I would do is put a 40 yr old filter on anything that is going to be running.
Re: 66 Belvedere II - Oil Filter [Re: JohnRR] #1507900
09/27/13 09:00 AM
09/27/13 09:00 AM
SD
Z
zrxkawboy Offline
zrxkawboy  Offline
Z
SD
For reference, the "8A" crosses to a Wix 51515/NAPA Gold 1515 (same filter). Hastings is good also.
It's Swifty! Swifty, you toad sucker!
