I have a 49 wayfarer, with a dakota front, need to make engine mounts. The bare engine block is hovering in place, had to cut the firewall. Original dakota engine was forward and offset right where I need it. I just need to know the distance needed from the front of the water pump pulley to a radiator needed, since I don't have a fan blade to see this. Thanks, Andy
