I have been calling around getting recommendations on a new carb lately and received the following suggestions. What do you think would be best for my set-up?
'72 Cuda Street car with a trip or two to track a year. 440, 727, 3600 stall vert, manual valve body, OOTB Eddy Alum heads, 10:1 compression, Eddy RPM Dual Plane, 3.55 gear, 28" tire, .494/.513 lift cam, 226/234 @ .050, rpm range 1800-6200
I wanted to go with mechanical secondaries and no choke.
Quick Fuel: Q-850 or Q-850AN
AED: 750HO or 750HOM
Pro Systems: 950HP based carb flowing 830-840cfm
BLP: 950HP based carb
FBO Systems (Don Gould): Q-750 (said the Q-850 may pick up a couple hundredths on the big end but since I am only bracket racing and do more street driving the Q-750 will be much more responsive)
