Is there a difference on dust shields for 4speeds? #1507667
09/25/13 08:41 PM
09/25/13 08:41 PM
Athens, Greece
Pyper70 Offline OP
Pyper70  Offline OP
Athens, Greece
My buddy is missing his, the flywheel is exposed and I would like to cover it up in case a rock finds him on the road....Is it a standard dust cover or do I need to crawl under there and take measurements. Its a 440 4 speed in a 72 B-Body
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: Is there a difference on dust shields for 4speeds? [Re: Pyper70] #1507668
09/25/13 08:58 PM
09/25/13 08:58 PM
central P.A.
HEMIDOG 70 Offline
HEMIDOG 70  Offline
central P.A.
Yes the big block covers are different for 10.5 " or 11" bell housings.Check Brewers site.
http://www.brewersperformance.com/products.asp?cat=263
Re: Is there a difference on dust shields for 4speeds? [Re: Pyper70] #1507669
09/26/13 10:23 AM
09/26/13 10:23 AM
Ohio
64dodge572 Offline
64dodge572  Offline
Ohio
Easy way to tell the diff between 10.5"/11" BB. 10.5" will have 2 places where the ballstud for the z-bar can screw in. 11" will only have one place. This however only applies to pass car applications.
Brewers Performance Inc.
4-speed transmission and parts specialists
PH 937-947-4416 or 937-698-4259
FAX 937-947-4419
