New Rallye Dash Harness..Not Correct #150756
11/14/08 03:42 AM
11/14/08 03:42 AM
Anonymous OP
Anonymous OP
Well all:
I bought a new chally rallye wiring harness (OK...ebag special). But this is new in package.
Labled for a 74 Chally, Rallye, with guages.
I believe this thing was made by Fellwick.
I unpackaged it and checked it out.
Looks good, except there are a few things wrong.
Either this was a mis-labled package, or it's a serious goof.
I'm supposed to have the seat belt interlock system connections...none there.
3 speed wiper motor connector had a 5 pin connector, and a seperate 2 pin connector...not correct. (I could make it work tho).
Yellow 3 prong accessory connector was not present, but there were 2 singles available.
I checked this all out with my factory wiring manual, and the wiring colar coding is correct.
Could this be a bad repro, or could this be a mis-labled harness for another year ?
Regardless, I am not going to use it.
Re: New Rallye Dash Harness..Not Correct #150757
11/14/08 04:00 AM
11/14/08 04:00 AM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
Fellwocks Auto-Parts Restoration has changed their name and will now be operating under the name Classic Auto-Parts Restoration.
Wiring Harnesses
Re: New Rallye Dash Harness..Not Correct #150758
11/15/08 03:21 PM
11/15/08 03:21 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Well all:
sounds like a 71 version... dunno on E bodies, but 71 B bodies wiper switches are 2 plugs instead one even using same wires quaintity and color codes
Re: New Rallye Dash Harness..Not Correct #150759
11/15/08 08:07 PM
11/15/08 08:07 PM
Anonymous OP
Anonymous OP
NachoRT71:
You get are correct !
I just got a hold af a 70 Chally wiring diagram, and dicovered that it is, in fact a 70 Rallye harness (possibly 71).
The wiper motor connectors are 2 pieces, and the accesory connectors are as a 70.
Now I have a new Chally rallye harness that I don't need !
Anyone intereted ?
