Well all:
I bought a new chally rallye wiring harness (OK...ebag special). But this is new in package.
Labled for a 74 Chally, Rallye, with guages.
I believe this thing was made by Fellwick.
I unpackaged it and checked it out.
Looks good, except there are a few things wrong.
Either this was a mis-labled package, or it's a serious goof.
I'm supposed to have the seat belt interlock system connections...none there.
3 speed wiper motor connector had a 5 pin connector, and a seperate 2 pin connector...not correct. (I could make it work tho).
Yellow 3 prong accessory connector was not present, but there were 2 singles available.
I checked this all out with my factory wiring manual, and the wiring colar coding is correct.
Could this be a bad repro, or could this be a mis-labled harness for another year ?
Regardless, I am not going to use it.
