Required maintenance dash light #150737
11/14/08 12:42 AM
11/14/08 12:42 AM
Stow ,Ohio
demon440 Offline OP
demon440  Offline OP
Stow ,Ohio
I just bought a 91 Dakota with a 318
2 wheel drive,standard cab.
today a required maintenance light came on.
I am assuming it means time for an oil change
or something of that nature.
How do I know what maintenance is required and
how do I reset the light?
Re: Required maintenance dash light [Re: demon440] #150738
11/14/08 07:47 AM
11/14/08 07:47 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
That light was for the emissions.Ma wanted you to at least check like the O2 sensor but really wanted them changed.Some had a switch behind the dash that had to be reset to shut it off.Been a long time since Ive played with one at work.Have to look in AllData to see reset procedure.Rocky
Chrysler Firepower
Re: Required maintenance dash light [Re: therocks] #150739
11/14/08 09:50 AM
11/14/08 09:50 AM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
My 89 van has one. Requires a scan tool to reset.
Re: Required maintenance dash light [Re: demon440] #150740
11/14/08 01:56 PM
11/14/08 01:56 PM
PA
70Duster Offline
70Duster  Offline
PA
The light is a reminder to check or change the oxygen sensor. It is not indicative that something is wrong. The easist way to permanently disable it is to remove the bulb.
Re: Required maintenance dash light [Re: 70Duster] #150741
11/14/08 02:12 PM
11/14/08 02:12 PM
Stow ,Ohio
demon440 Offline OP
demon440  Offline OP
Stow ,Ohio
Thanks for the replies guys.
I will look to see if there is a
switch, if not I will get it scanned.
Hmm, maybe just yank the 318 and
install 440 ...
