Small block oil pump priming #1507186
09/24/13 10:30 PM
09/24/13 10:30 PM
1970_EK2AAR Offline OP
When using a drill motor and Mopar hex drive priming rod, what direction should the pump be turning . . . clock or counter-clockwise? Thanks
Re: Small block oil pump priming [Re: 1970_EK2AAR] #1507187
09/24/13 10:48 PM
09/24/13 10:48 PM
Clockwise. Be sure & hand turn the crank till you hit the 2 sweet spots where each respective head (rocker arm assy) is getting lubed.
