Just bought a nice 2wd pop top ramcharger
#1507034
09/24/13 07:01 PM
09/24/13 07:01 PM
Posts: 5,443 ME
79machocharger
ME
Just bought a 2wd pop top ram charger with no motor but rock solid and straight. Got a great deal on it and couldn't pass on it. I had a 2wd ramcharger a while back and I didn't realize it at that time how hard they were to find. I've kind of been looking since but haven't really seen any thing that was decent until this one. I'm up in the air on how I want to do this one up, I'm either going to go with the pick m up decals or 77/78 macho powerwagon decals where it's a 78. My last one was a 79 so I went with the 79/80 macho powerwagon scheme on it. I definitely going to be painting it black either way. A black ramcharger with the 77 macho paint would look pretty neat in a 2wd version. I also just picked up a low mileage 2003 5.9 magnum style motor for it today from a local junkyard. I've always wanted to build one of these motors up with a better cam, air gap intake, nice carb, headers. Later on I wouldn't mind adding a four speed in to it. I'm going to install the black plaid and white interior out of my macho trailduster with the fold up rear seat that wasn't offered till 1980. The wagon wheels will also be installed with the yellow pin striping if I do it up like a macho. Should be a fun ride cant wait to get started on it.
Re: Just bought a nice 2wd pop top ramcharger
[Re: 79machocharger]
#1507043
09/25/13 02:43 PM
09/25/13 02:43 PM
Posts: 5,302 CA, Proprietor; The "PALOMINO"...
dynotune440
nice lookin AZ ramcharger....IIRC it was 1500 bucks. honestly I would make it look like an 80, but leave the 4wd graphic off of the gate. I would also make it look like the 80 T/D macho that you have....in fact, there is your pattern..color as well, Bright Yellow looks good!!or is it impact yellow?....
Dinuba, California, Home of the PALOMINO ranch and 440 truck farm, where dodge trucks have a home. Have Four 1979 dodge PALOMINO trucks now.
[Re: dynotune440]
#1507045
09/25/13 03:59 PM
09/25/13 03:59 PM
Posts: 5,443 ME
79machocharger
ME
That's funny you said that as I thought about going that route with it as well. It is a neat color combo, and the stripe kit is very easy to do. It's the same color as your 80, so what ever color that is?
#1507047
09/25/13 04:42 PM
09/25/13 04:42 PM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
iirc the 2x RCs have the 4X floors.. You need the part that 76DB has the OD833 out of a truck or van. My spare is out of a 90. The shifter is a normal Hurst shifter with a truck style mounting plate. Most of the hyd bells are double patterned for the NP435/OD833...
I am truckless..
[Re: adventurer]
#1507049
09/26/13 12:18 AM
09/26/13 12:18 AM
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
I was considering an 80s model 2X here in Wa on Craigs Flakes. . . The ad said no engine. Come to find out that it did have an engine in it. Then Polarapete bought it and the engine let go half way home to his house. His darling wife rescued him by bringing the trailer to get him.. ..
I am truckless..
[Re: 340SHORTY]
#1507050
09/27/13 04:39 AM
09/27/13 04:39 AM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
I did buy that '86 Larry and the 360 engine was a runner. The problem was that the PO changed the fuel pump and forgot to put a clamp on the inlet side hose!! The engine would run for a few minutes, start sucking air and quit. I trailered it home and started and drove it off the trailer. I have everything to make it run except the driveshaft, a Built 440, Pat Blais race 727, two different converters to try, a narrowed Dana 60 with 4.10s , nice wheels & tires, etc. etc. I cut the floor out of the back to mount the aluminum fuel cell today. Once I get the back done, I will turn the truck around and back it into the garage so that I can put in the new van pocketed control arms and fill the huge holes in the fire wall. Just some assembly required LOL
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: 77ProStreet]
#1507053
10/18/13 09:56 AM
10/18/13 09:56 AM
For myself, I never really understood the idea of a 2wd RC/TD. Ok, maybe cool with the top down and the HP up but in my mind the thing was always intended as a 4wd. Your mileage may vary.
At any rate and FWIW: the donor slots look like factory 15x8 and the LRE guys will scoop them up for a decent price. Much tougher to find than passable macho clone wagons.
If you end up changing the mirrors, maybe hit me up about the old ones.
