xr1 build does one run yet ### pics added #1506611
09/23/13 09:53 PM
09/23/13 09:53 PM
bean town ....Ca
W
WHITEDART Offline OP
W
bean town ....Ca
well we are in fall now just wondering how that build is going
Re: xr1 build does one run yet [Re: WHITEDART] #1506612
09/23/13 10:10 PM
09/23/13 10:10 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
XR1 maybe. XR2 depends on what you call run?
Re: xr1 build does one run yet [Re: WHITEDART] #1506613
09/23/13 10:24 PM
09/23/13 10:24 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
It's going to happen, be patience grasshopper.
Re: xr1 build does one run yet [Re: Leon441] #1506614
09/23/13 11:06 PM
09/23/13 11:06 PM
bean town ....Ca
W
W
bean town ....Ca
found another problem because the lifters were all over the board had to run a key way lifter that only cost 2200$ but because kent ritter can not drill a hoe to save his life. the oil galleys that he drilled right through the center of the lifter boar is a 1/2in to high the keyed bushing can not be pressed in all the way.. because the slot will inter in to the oil galley which would cause 16 oil leaks..so that been said CAM FX is going to make a custom $$$$$$$$ key way lifter.`400 LONG. and that is 400 longer than a sbf lifter which is something like 250 longer that a standard mopar lifter do the math 650long the lifters kent ritter sold me are 650thou to short what a dummy..
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: xr1 build does one run yet [Re: WHITEDART] #1506615
09/23/13 11:16 PM
09/23/13 11:16 PM
New Smyrna Beach FL
scottb Online content
scottb  Online Content
New Smyrna Beach FL
That block sounds like a nightmare I would stay away way away
Re: xr1 build does one run yet [Re: WHITEDART] #1506616
09/23/13 11:50 PM
09/23/13 11:50 PM
bean town ....Ca
W
W
bean town ....Ca
1st http://i1291.photobucket.com/albums/b557/dodgedart1/SAM_0071_zps34de3101.jpg?t=1379990825 that is a pick of a jesel 9.37 mopar 9 lifter that he sold me over a 1/2in to short thanks again kent
Re: xr1 build does one run yet [Re: WHITEDART] #1506617
09/24/13 05:59 AM
09/24/13 05:59 AM
IL. Jerseyville
jg309 Offline
jg309  Offline
IL. Jerseyville
whitedart those lifter busshings go in different than a r5 do,look real close @ where the oil holes are, if you get that far & need a diagram let me know, john, getting real close on our xr-2, minachne shop just had to finish bushings & finish cutting deck height, but heads & intake not ready anyway
Re: xr1 build does one run yet [Re: jg309] #1506618
09/24/13 07:13 AM
09/24/13 07:13 AM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
Time for a Hemi...
Re: xr1 build does one run yet [Re: WHITEDART] #1506619
09/24/13 09:46 AM
09/24/13 09:46 AM
long island new york
K
kingdust Offline
kingdust  Offline
K
nice crank! hope things get straitened out.
LIFE IS A LESSON,YOU LEARN IT WHEN YOUR THROUGH!
Re: xr1 build does one run yet [Re: WHITEDART] #1506620
09/24/13 08:17 PM
09/24/13 08:17 PM
bean town ....Ca
W
W
bean town ....Ca
this block is different than yours this is the new style.. he drill the oil galley right threw the center of the lifer boar. like a chevy but he drilled it a 1/2in to high I will try to get some pics
Re: xr1 build does one run yet [Re: WHITEDART] #1506621
09/24/13 09:42 PM
09/24/13 09:42 PM
New Smyrna Beach FL
New Smyrna Beach FL
Whats the cost of a new Ritter block compared to a new R block
Re: xr1 build does one run yet [Re: scottb] #1506622
09/24/13 10:02 PM
09/24/13 10:02 PM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
I'm very confused as to why one of these is not running as well. There are many competent engine/machine shops around the US and plenty of people with deep pockets. Am I missing something?
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: xr1 build does one run yet [Re: scottb] #1506623
09/24/13 10:06 PM
09/24/13 10:06 PM
bean town ....Ca
W
W
bean town ....Ca
ritter was 3000$ PLUS 4000$ TRYING TO FIX IT. there are so many cool thing about this block. just wish kent would get it together
Re: xr1 build does one run yet [Re: scottb] #1506624
09/24/13 10:06 PM
09/24/13 10:06 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
2950 for the ritter. r3 is about the same. that is for the 48*.
Re: xr1 build does one run yet [Re: DemonDust] #1506625
09/24/13 10:18 PM
09/24/13 10:18 PM
bean town ....Ca
W
W
bean town ....Ca
kent is very old school . for years mopar paid for his racing for them to sink a ton of cash in a block for his comp cars was no big dill. but for your normal guy today we don't have those resources. and there has been some hitters try to build a motor using one of these and they scraped it.. kent dose not use the internet so has no idea what he has done by burning so many people with these blocks.sad story
Re: xr1 build does one run yet [Re: rickraw] #1506626
09/24/13 10:21 PM
09/24/13 10:21 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I work at a dealer and got my R3 delivered for $2650 out the door. I looked at the Ritter block and it looked good on paper.... but I was swayed to go the R3 route despite it's possible issues.
Re: xr1 build does one run yet [Re: J_BODY] #1506627
09/24/13 10:29 PM
09/24/13 10:29 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
That was a smart move.
Re: xr1 build does one run yet [Re: J_BODY] #1506628
09/24/13 10:30 PM
09/24/13 10:30 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
After years in the machining trade I can almost visulize this block getting machined by someone who really didnt give a rip about the end result. Too many people out there who just knock holes and cut without a clue what they were doing. Slubheads making garbage then acting like everything will just work itself out on its own. Kent Ritter needs to stop all production on everything, recall every block he sold, and figure out his problems now. Then re-introduce it to the market. If not this whole block option will be gone shortly. Guaranteed.
Re: xr1 build does one run yet [Re: rickraw] #1506629
09/24/13 11:39 PM
09/24/13 11:39 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
after my stage VI and W5 experience it was reeaally hard to spend money like that on a "mopar performance" part..... believe me!!
Re: xr1 build does one run yet [Re: J_BODY] #1506630
09/25/13 03:02 AM
09/25/13 03:02 AM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
And we wonder why people are putting LSX into mopars
