Dual or Single Plane Intake
#1506502
09/23/13 04:28 PM
09/23/13 04:28 PM
Posts: 5,444 Indiana
YO7_A66
Indiana
I am currently running an Edy RPM intake on my 340 and have been for the last 8 years. Over those years, I have made some combo changes and I am now curious if the RPM is still the best intake that I could be using. Is this dual plane still the best choice or would my combo help out with a single plane intake? If so, which model. Some of my specs are listed below. Thanks
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
Re: Dual or Single Plane Intake
[Re: YO7_A66]
#1506503
09/23/13 05:29 PM
09/23/13 05:29 PM
RapidRobert
I'm not sure & as you know the RPM has a heck of a good rep. I would see how much vac you have on either/both planes at WOT which is a good indication if the carb venturi's are too small & are restricting the flow if you have over 1 in hg. This would apply to WOT IF you spend a significant amount of time there (WOT)
[Re: JohnRR]
#1506505
09/23/13 05:37 PM
09/23/13 05:37 PM
YO7_A66
Indiana
My WOT vacuum reading shows 0 on a mech guage.
This is a street car but WOT is a big part of how I drive it.
[Re: AndyF]
#1506509
09/23/13 07:15 PM
09/23/13 07:15 PM
Challenger 1
Cincinnati, Ohio
At WOT a single plane will work significantly better than a dual plane. So it just depends how important WOT performance is to you compared to part throttle performance.
I ran a dyno test recently where the dual plane intake lost 100 hp when compared to a race prepped single plane. The bigger issue is that the AF ratios are often all over the map when running a dual plane at WOT.
At part throttle the dual plane is much better than a single plane so there is a compromise that has to be made.
Thanks, it confirms what I have found over the years.
My first 340 at 16 years old had a weiand single plane manifold on it which came in my 72 challenger. I used it for 20+ years, the manifold on a few different 340s.
Thinking I needed a new more modern manifold I bought a performer. It was terrible compared to my old single plane weiand which I sold.
Sold the performer and bought a performer rpm and it was a little better but no where near my old weiand at WOT. Still have the rpm manifold but got a 340victorjr and now it is closer to what the old weiand was. It does have edlebrock heads on it now and it runs well on the street at idle. I've been using it since 2007. I did all my testing with iron 340 heads.
I have idled it over a hour in Vegas this past July in 105 temps with the AC cranking. It handles it fine. My wife drives the car also.
I got to the feel the WOT, give me a single plane.
The icing on the cake for me is, there are no heat risers provisions on the victor manifold or heads. Perfect for todays pump gas and my 1405 edlebrock carb.
[Re: AndyF]
#1506510
09/23/13 07:17 PM
09/23/13 07:17 PM
Triple Threat
Renton Washington
I don't think you'll see significant gains from a single plane up top, and you'll likely lose a bit down low. I would stick with what you've got.
[Re: AndyF]
#1506512
09/23/13 09:45 PM
09/23/13 09:45 PM
YO7_A66
Indiana
Thank you everyone! Andy, My WOT readings are all over the place and I have two seperate exhausts side to side with each side having an A/F sensor. At idle, they are both within .4, off idle up past 70mph, they are both within .2. But at WOT and no matter what my jetting may be even staggered side to side and swapped stagger to opposite side, my WOT is about .6 on average side to side. This was the main reason that I asked this question. Would there be any gains by swapping the RPM intake for the RPM Airgap? I just looked up the Torker II and it is a single plane with a power range of 2500-6400rpms. How would this compare to my RPM?
Thanks again to all.
[Re: BSB67]
#1506514
09/24/13 08:48 AM
09/24/13 08:48 AM
Challenger 1
Cincinnati, Ohio
I would be very surprised if there was any performance gain anywhere in the rpm range going from an RPM to a single plane with a motor and cam that small.
Have you guys ever tried a single plane manifold?
My cam is smaller...And I here to say a single plane runs way better up top than a dual plane.
I guess you didn't read or believe what AndyF found on a dyno?
[Re: Challenger 1]
#1506518
10/04/13 08:15 AM
10/04/13 08:15 AM
YO7_A66
Indiana
I am still thinking out loud here about the single plane intake idea. What about the Weiand Excellerator #7545? It specs out as a low-rise single plane with a 1500-6800 rpm range? I have a 3800rpm converter with 3.91's and 26" tires. What do you think about this intake for a streeter? I did not see them sold new, so this one might have to be found used.
Thanks again.
[Re: YO7_A66]
#1506519
10/04/13 05:04 PM
10/04/13 05:04 PM
Posts: 25 Glendora, CA
MYBD318
Glendora, CA
I think the bigger problem will be getting the manifold pictured to fit on a chrysler. Stick with what you've got. .02 Mike
Still a teen just a 416
