C Body conversion to manual steering-adapter available? #1506491
09/23/13 03:28 PM
09/23/13 03:28 PM
Iron Station, NC
furygt Offline OP
furygt  Offline OP
Iron Station, NC
I would like to convert my '68 Sport Fury to manual steering. I know that the C Body & B Van steering boxes are different than the A/B steering boxes.
Is there an adapter available for this conversion or do I need to swap in a manual steering column? I understand that the manual steering column in a C Body is longer than a power steering column.
I know that the A/B column to manual steering box adapter will not work.
Thank you in advance for your help.
Bill
Re: C Body conversion to manual steering-adapter available? [Re: furygt] #1506492
09/23/13 06:23 PM
09/23/13 06:23 PM
mt. pleasant, PA
Diplomat440 Offline
Diplomat440  Offline
mt. pleasant, PA
i made my adapter on my 73 newport.
i used part of an aftermarket steering shaft from an 80s dodge truck welded to mine, worked great. easy to get on and off since it is made to slide
i bought the steering shaft at the junk yard for $5
[image][/image]
Re: C Body conversion to manual steering-adapter available? [Re: Diplomat440] #1506493
09/23/13 07:04 PM
09/23/13 07:04 PM
Iron Station, NC
furygt Offline OP
furygt  Offline OP
Iron Station, NC
Was that part out of a pickup or a van?
Bill
Re: C Body conversion to manual steering-adapter available? [Re: furygt] #1506494
09/23/13 08:43 PM
09/23/13 08:43 PM
mt. pleasant, PA
Diplomat440 Offline
Diplomat440  Offline
mt. pleasant, PA
4 wheel drive pickup, aftermarket,replaces the original shaft with the square box style coupler that always craps out on the trucks.
new their like $190
i've used other ujoint style couplers from k-cars and stuff like that to convert other cars.
splines are the same alot of the time, and the ujoint syle seems eliminate one potential source of slop.
Re: C Body conversion to manual steering-adapter available? [Re: Diplomat440] #1506495
09/23/13 10:39 PM
09/23/13 10:39 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
Is the 68 same as a 65 or are they different?
Re: C Body conversion to manual steering-adapter available? [Re: markz528] #1506496
09/23/13 10:53 PM
09/23/13 10:53 PM
Iron Station, NC
furygt Offline OP
furygt  Offline OP
Iron Station, NC
Mark,
'65 and '68 use the same steering boxes.
Bill
