4-spd. od rebuild help #150642
11/13/08 10:38 PM
11/13/08 10:38 PM
pacific northwest
W
wings471 Offline OP
wings471  Offline OP
W
pacific northwest
I'm going to attempt to rebuild my /6 4-spd od trans. Never taken one apart before. What is the best, easy to understand ( p i c t u r e s ) guide for a novice. Actually the taking apart part doesn't worry me...it's the putting it back together so it works as it should, part, I'm concerned about. I have a Haynes book for 'A' body cars but it doesn't address the 4 spd. transmission. Thank you.
Re: 4-spd. od rebuild help [Re: wings471] #150643
11/13/08 10:45 PM
11/13/08 10:45 PM
Rome, Ga
sbhpcb Offline
sbhpcb  Offline
Rome, Ga
Do a Google for Mopar 833 od. I had a website that showed and described everything when I rebuilt mine. The computer got fryed that I had it saved in.
Re: 4-spd. od rebuild help [Re: sbhpcb] #150644
11/14/08 12:38 AM
11/14/08 12:38 AM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
Buy a factory service manual (FSM). If you're just after the A-833 O.D. section, any '75+ A, F, or van manual will have a section that covers that trans. You can find them on eBay all day for a fair price.
Re: 4-spd. od rebuild help [Re: In_The_Pink] #150645
11/14/08 03:46 AM
11/14/08 03:46 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
where are you located in the PNW. I will be glad to walk you through it...
I am truckless..
Re: 4-spd. od rebuild help [Re: 340SHORTY] #150646
11/14/08 10:43 AM
11/14/08 10:43 AM
pacific northwest
W
wings471 Offline OP
wings471  Offline OP
W
pacific northwest
Thanks very much for the offer 340shorty I live in central Oregon. I'm thinking this will most likely take me a week or so to complete if I work on it a few hours each evening. Once I find the information and read it through a few times before I start tearing into the trans., I should be alright. Thank you again for the generous offer of your time and to the other members for their input as well.
Re: 4-spd. od rebuild help [Re: wings471] #150647
11/14/08 11:03 AM
11/14/08 11:03 AM
Wheatfield, NY
Cuda340 Offline
Cuda340  Offline
Wheatfield, NY
I used these.
http://www.moparmusclemagazine.com/projectbuild/5134/
http://www.slantsix.org/articles/4-speeds/ODA833fourspeed1.htm
Make a dummy shaft for the cluster gear out of 3/4" electrical conduit.
Good luck it is quite easy.
