Replacing cruise switch on 2002 Dakota #1506081
09/23/13 12:40 AM
09/23/13 12:40 AM
Middle TN
da50r Offline OP
da50r  Offline OP
Middle TN
My cruise switch broke and is loose, but still on the wheel. I'm guessing some little plastic tab broke. Can I easily change this? Or is this a $4500 dealership removes airbag fix to get to the 2 little screws? Thanks guys.
Re: Replacing cruise switch on 2002 Dakota [Re: da50r] #1506082
09/23/13 11:07 AM
09/23/13 11:07 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
You can do it yourself. Been awhile since I took apart my Dakota steering wheel, I don't remember if you have to remove the airbag first, but there's 2 screws that hold the switches in place, located on the back side of steering wheel if I remember correctly. Or maybe the screws for the airbag were on the back and the hardware for switches was under the airbag.
Just unhook the battery for a few minutes then look for hardware to remove. It wasn't that hard to do, and nothing blew up in my face.
**Photobucket sucks**
Re: Replacing cruise switch on 2002 Dakota [Re: da50r] #1506083
09/23/13 01:29 PM
09/23/13 01:29 PM
Hershey, PA
73MagDuster Offline
73MagDuster  Offline
Hershey, PA
Remove the 2 airbag bolts from the back of the wheel and the Torx (T15 I think) head screws for the cruise switches will be revealed. Remember to unhook battery for 15 minutes or so as a precaution. It's an easy breezy job.
Re: Replacing cruise switch on 2002 Dakota [Re: 73MagDuster] #1506084
09/23/13 05:03 PM
09/23/13 05:03 PM
Middle TN
da50r Offline OP
da50r  Offline OP
Middle TN
cool thanks
Re: Replacing cruise switch on 2002 Dakota [Re: 73MagDuster] #1506085
09/25/13 09:50 PM
09/25/13 09:50 PM
hiding in illinois
slax69gts Offline
slax69gts  Offline
hiding in illinois
mine are loose on my 99 dakota r/t i picked up at the nats. you just made my life a bit easier too.
Re: Replacing cruise switch on 2002 Dakota [Re: 70Cuda383] #1506086
09/27/13 11:37 PM
09/27/13 11:37 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
There was a TSB on the air bag.Ma wanted you to hook it up.Then with key on put the neg battery cable on.I guess they had a few blow when techs hooked the battery up first then reached inside to turn the key on.Ive never had one go off but you never know.Rocky
Chrysler Firepower
