Re: Running a very low compression Engine on race fuel
[Re: mopar dave]
#1505967
09/25/13 09:46 AM
09/25/13 09:46 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
yes, shell v-power 93. I was told by vp fuels its the only pump gas with out all the other junk in it. smells like race fuel when it burns. don't know just whats in it, but its the best pump gas around here and if your in Michigan, Kroger gas seems to be the same thing as their affiliated with shell and have the same race fuel smell. been runnin it all summer and at the track,no issues with 11.3:1 compression(195 cranking) 36* timing. look it up on the web,theirs plenty written about it.
Bee Ess NO pump gas 93 smells like race fuel. I've run them all. They all produce the same results. I usually run either BP 93 or Shell depending on what side of the street I'm on. We also have an Exxon and Sunoco I use from time to time. I will say this last year I had a gallon and a half of 110 left and boy the lawnmower loved it.. smelled like race day as I was cutting the grass....lol
[Re: Mr.Yuck]
#1505968
09/25/13 10:36 AM
09/25/13 10:36 AM
Challenger 1
Cincinnati, Ohio
When I put race gas in my mower, it shoots all the clippings into my neighbors yard. lol
[Re: mopar dave]
#1505970
09/25/13 12:08 PM
09/25/13 12:08 PM
Posts: 13,363 Marion, South Carolina [><]
an8sec70cuda
well, then you haven't ran the gas that I use. i'v been acused of runnin race fuel a few times. I know it has 11% alcohol and toluene. propably why it has a race fuel smell. look it up on the web, has a lot of good stuff in it.
It may be different up there, but the Shell V power 93 down here that I use occasionally in my car definitely doesn't smell like race fuel. I've been just as fast at the track w/ no name premium 93 from Sparky's Fireworks as I have w/ Shell, Amoco, BP, Sunoco, etc. Went 9.65 at 140 mph back in April this year w/ gas from the fireworks store. My car slows a tenth and a little over 1 mph on VP 110, but the only thing I changed was the fuel. Never tried playing w/ timing or anything else.
[Re: Challenger 1]
#1505972
09/25/13 03:48 PM
09/25/13 03:48 PM
Posts: 8,165 Left Coast
BobR
Left Coast
Why in the world wouldn't he go make a couple runs on 93 octane? He could even put a dash of grape fuel fragrance from Summit, smells like race fuel, I've used it a couple times for car shows and car cruises.
No it does not smell any where close to real race gas. I use the stuff too some times, the stuff from summit is weak. Even the good stuff don't smell like race fuel.
I have ran 110 leaded race gas in a 10.5-1 340 since 1983.
Then I switched to 92 octane about 6 years ago because I drive my car a lot now a days and I can't afford race gas even though I sell it at work. And I'm here to tell you the race gas runs way better in in a low compression motor and cooler.
Plus I have ran straight race gas in in dirt bikes, jets skis, chain saws, weedeaters, 2 stroke dirt bikes love it, generators and many other motors and they all ran much better on race gas. I would mix it half and half with 91 unleaded most of the time, because full strength is not always needed. But I have burned a bunch of it straight and it won't hurt even the weakest motor.
I have been on camping trips to the lake, we ride jet ski/ wave runners during the day and dirt bikes at night. I would bring plenty of mixed race fuel for our 2 stroke dirt bikes.. I would always provide some gas for the jet skis and everyone and I mean everyone would be fired up how good there jet skis ran with it. To the point that I sell lot's of race gas to bike and water craft people now a days.
Everything runs better on race gas, I'm sure.
My 71 stock 340 sure as hell does run better with race gas.
I ran straight race gas in a 87 dodge ramcharger with a 360 quradrajet carb at graval rama here in town and my truck ran the quickest on straight race gas at the 300' sand drags. Then I ran the same ramcharger on race gas and nitrous oxide and it ran 14.20 in the quarter on asphalt with stock 360. I have done plenty of back to back testing years ago to see if it really did help and it always helped. Time clocks don't lie.
My buddy has a dyno in his engine building shop. Race gas always makes more power. Pump gas is designed for almost everything but performance. Race gas is designed exactly for performance. There are differences in race gas. One might be better than another.
[Re: an8sec70cuda]
#1505973
09/25/13 03:52 PM
09/25/13 03:52 PM
BobR
Left Coast
In California the gasoline is produced to a very specific recipe and there is virtually no difference between brands. They even will exchange fuel from brand to brand when convenient. This is expecially true with independent gas stations. There may be 4 different kinds of fuel in one tank.
[Re: BobR]
#1505974
09/25/13 04:00 PM
09/25/13 04:00 PM
an8sec70cuda
Yessir. I used to work w/ a fella that drove a fuel delivery truck...said they used to fill tanks at several different stations (different brands) from the same truck/tanker all the time.
[Re: mopar dave]
#1505977
09/26/13 12:59 AM
09/26/13 12:59 AM
Posts: 52,972 Romeo MI
MR_P_BODY
If I recall the number right anything over 32 degrees you start loosing efficiency so if your at 40* your fuel is burning too slow and needs to be less octane so you can pull it back... BUT the heads are important here... a head can be more efficient in itself so it comes down to what is efficient for your set up... Don... I'm sorry your brother has this smell fetish but he needs to get over it and start making power with less octane... I will say he will make more power with less octane and it could be moose piss 87 if he buys from the same place all the time so the tune can stay the same
[Re: mopar dave]
#1505980
09/26/13 11:51 AM
09/26/13 11:51 AM
MR_P_BODY
engine masters has a Pontiac build that the builder says a cylindrical dish piston is more efficient therefore requiring less timing. my pistons have a D dish. so maybe the piston top have as much effect on timing as the chamber shape?
The piston top makes a difference also.. its just a matter of how easy and efficient the whole thing burns
[Re: mopar dave]
#1505983
09/26/13 03:27 PM
09/26/13 03:27 PM
dogdays
No, that's how they looked in the engine as he was putting the heads on. I understand not messing with the interviewee, but that whole line about the cylindrical dish being best is so wrong. Maybe that's why I don't do interviews and articles!
R.
PS, Steve, if you eventually read this, kudos to you for generally getting the English right. I recently saw a hunting magazine article where there must have been 15 mistakes on the first page!
