Re: GTX Wheel opening moldings???
[Re: 68gtx]
#1505819
09/22/13 05:56 PM
09/22/13 05:56 PM
Posts: 718 new york
paris401
new york
Just purchased a set of moldings for my 68 GTX. Rears fit ok but fronts have a large gap at the bottom front and rear. Also I noticed they are not drilled?? Only 2 holes are drilled at the top of each molding. Whats up with that?? So not only do I have to shape them to fit I have to try to mark and drill them to oe holes. Someone making a better repro?? Thanks Larry J
who makes em?? I'm looking for my 69.5 bee, and see em from metro and goodmark, both suppose to be USA made, and dales cuda shop also sells em...
I had heard from others that the re-pops don't fit like a glove...
[Re: 68gtx]
#1505821
09/22/13 06:17 PM
09/22/13 06:17 PM
Posts: 718 new york
paris401
new york
Tried to order them from Dales but not in stock. So I ordered them from Metro. I have done a lot of GM and Ford stuff. They are all pre-drilled and not many issues with fitment. But looking on the web it looks like the repros for most Mopars have issues?? Any suggestions would be helpful!!!!! Thanks Larry J
I posted a question about em the other day... so far, not a comment back...I sent a message to dales.. awaiting his comments...
[Re: 68gtx]
#1505822
09/22/13 06:40 PM
09/22/13 06:40 PM
RSNOMO
Moparts Torchbearer
Moparts Torchbearer
[Re: 68gtx]
#1505828
09/23/13 05:48 PM
09/23/13 05:48 PM
Posts: 21,519 N.E. OHIO, USA
A12
N.E. OHIO, USA
Thanks for all the info!!!!
Welcome
[Re: A12]
#1505829
09/23/13 09:32 PM
09/23/13 09:32 PM
Posts: 2,766 Appleton, Wisconsin
rtmike
Appleton, Wisconsin
I bought a set for my coronet, and test fit them. They are not perfect for sure. I think the reason they are not predrilled is so that the fit can be made right with out the hole location being the issue. Mine are pre-drilled, and I will be drilling some additional holes either in the vendor or the trim.
Its not primer its perma gray.
