2001 Grand Caravan maintenance ???'s
#150575
11/13/08 08:16 PM
11/13/08 08:16 PM
Posts: 9,116 Falconer, NY
KatFysh
Falconer, NY
A friend of mine bought an '01 Caravan recently with a 3.3l engine. He brought it over to me tonight to check it over for him. 1st} for future ref., is the engine a clearance engine? 2nd} how hard is it to change the rear valve cover gasket on this engine, in this vehicle? Does the upper intake have to come off? 3rd} how about the rear bank spark plugs? Can they be r&r'd from the bottom side or from the top? 4th} are these trannies as "problematic" as other Mopar trannies? 5th} it looks to have DexCool for antifreeze {the red stuff}, was it normal for Mopar to use this stuff in their engines? I thought it was a no no to use. I've seen the damage to the GM intakes,heads and head gaskets. The van has 155,000 on it and I was pretty impressed overall with it. It seemed pretty clean. Had some minor body work done to it and it needs the general things done like plugs,wires, tranny service, rear drums and an alignment. But these are a few of the concerns he has with it. Can you guys think of or let me know of anything to tell him to watch for? Thanks for your input.
When you decide to quit, THAT is the moment when you would've succeeded..
Re: 2001 Grand Caravan maintenance ???'s
[Re: KatFysh]
#150578
11/14/08 01:33 PM
11/14/08 01:33 PM
Posts: 9,312 SoCal
68HemiB
SoCal
The wife has a '98 3.3 with about 120k on the odometer. The source of much of my info is anecdotal from scanning boards online, as I have been fairly pleased with the service we have gotten so far. For us, there has been a relative lack of stuff breaking.
The rear plugs can be gotten out without tons of disassembly of intake, etc., but it's a challenge.
I had a cracked [plastic] radiator tank. It happens, but not super common. It's quite a job to swap one out, when compared to a 60's vintage musclecar.
The clock spring in the steering wheel had a recall, but I don't know if 2001 was a "bad" year. The symptoms include air bag light and/or no power to cruise control.
I don't know if it's an interference engine, but there's a timing chain (not a belt). I can't remember coming across anyone griping about the chains being a problem. (However, at 155K, it wouldn't be a bad idea to change it.)
Water pumps are super easy on this, and well worth it as preventative maintenance if you are doing anything in that area. Ditto the serp belt - put a new one in if you have the old one off for any reason. Early years had a issues with the serp belt tensioners, but that seems to have been resolved in later years.
The transmission design seems mature, and (if properly serviced) doesn't show up as a source of heartache for a large portion of the online population.
Salty environments play havoc with the metal coolant tubes for the rear heater (if so equipped).
Seems to be a tried and true transportation device that has pleased more customers than it has annoyed.
[Re: KatFysh]
#150581
11/14/08 10:57 PM
11/14/08 10:57 PM
Posts: 1,278 Mission BC
10sec440
Mission BC
1) the 3.3L is not a freewheeling engine. Having said that I've never heard of one crash. Usually when the chain goes it just gets noisey, they don't break. 2)The upper intake does have to come off to do the valve cover gaskets. I have found many to be simply loose, with the rubber backed steel (factory) gasket you can usually just tighten the bolts. 3)The intake does NOT have to come off to get to the plugs, although it would make it easier. If it is an AWD you will need to remove the small bracket at the top of the alternator and get #1 from the top. 4) tranny problems are fixed for the most part but nothing lasts forever. If you do need to do the tranny, make sure its a shop thats skilled on these tranny's, not just any tranny shop. 5) long life coolant started in 2000, its not as bad as Dexcool, but green is better (less harmful) The main thing here is the two MUST NOT be mixed.
As already said, they are great vehicles, the 3.3L is bulletproof.
[Re: 10sec440]
#150582
11/15/08 08:10 AM
11/15/08 08:10 AM
Posts: 21,079 Niles , Ohio
therocks
Niles , Ohio
Just use the new global stuff.Thats all we use at the shop.It mixes with anything.The rear plus are a pain but can be done without removing anythin.A lift makes it easier.Rocky
Chrysler Firepower
[Re: KatFysh]
#150583
11/15/08 08:55 AM
11/15/08 08:55 AM
Posts: 19,488 north of coder
moparx
i just "retired" my old bus, which was a 95. it had 312k on the clock with the 3.3 and 4spdaod. it still runs great. no problems with the engine-doesn't use any oil between changes[3-4k]. the only problems with it was one egr valve solinoid and plugs & wires. the trans works great,a couple of input/output sensors & regular fluid & filter changes. and i used dexron3 !!!!! [yes i know this is a no-no, but it also had a shift kit installed at 125k. don't know if this means anything or not...]i think the engine/trans combo would be similar to the 2001 as far as reliability. most of the time, front rotors need replaced when pads do. i've never had any luck turning 'em , and they are cheap enough anyway. check the brake & fuel lines for rust issues, as well as the spair tire & lowering cable for rust issues, especially the spair wheel around the center hole and the stud holes. it really sucks if you have a flat and the center hole wont fit because of rust build up and the nits won't stay tight because of same. [ not like you & me live in the "rust belt" ]. my "new" bus is a 2001, and the body was great, but i had a devil of a time getting the spair out to check it. the wheel was a mess !
[Re: KatFysh]
#150586
11/17/08 10:19 PM
11/17/08 10:19 PM
moparx
Wow. "Rust belt" ??!!! I don't even wear a belt..
my belt is ok, but as you know, my "hat" is a "little" crusty......
