what is correct attach hardware for hood insert 69 GTX #1505342
09/21/13 12:35 PM
09/21/13 12:35 PM
tucson az
frank Offline OP
frank  Offline OP
tucson az
Is there specific attach hardware for hood air inlet screens for an Air Grabber equipped (N-96) car or will something from the hardware store work? Car is a 69 GTX.
Re: what is correct attach hardware for hood insert 69 GTX [Re: frank] #1505343
09/21/13 01:16 PM
09/21/13 01:16 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
it's the same screws amd holddowns as the solid inserts , the screws are phillips head, self tapping
Re: what is correct attach hardware for hood insert 69 GTX [Re: JohnRR] #1505344
09/21/13 02:40 PM
09/21/13 02:40 PM
tucson az
frank Offline OP
frank  Offline OP
tucson az
I worded the question wrong. It's the nuts that attach to the studs that I need
Re: what is correct attach hardware for hood insert 69 GTX [Re: frank] #1505345
09/21/13 02:59 PM
09/21/13 02:59 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Those are sheetmetal nuts , like these at year one , not sure if you will find them at a hardware store
https://www.yearone.com/Product/1966-74-a-b-e-body/mt125
Re: what is correct attach hardware for hood insert 69 GTX [Re: frank] #1505346
09/21/13 03:00 PM
09/21/13 03:00 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Speed nuts, you can get them at a body supply outlet.
Sheldon
Re: what is correct attach hardware for hood insert 69 GTX [Re: JohnRR] #1505347
09/21/13 03:01 PM
09/21/13 03:01 PM
tucson az
frank Offline OP
frank  Offline OP
tucson az
Copy all. Thanks
Re: what is correct attach hardware for hood insert 69 GTX [Re: frank] #1505348
09/21/13 03:34 PM
09/21/13 03:34 PM
Avondale AZ
Prodart440 Offline
Prodart440  Offline
Avondale AZ
Not to hijack the thread, but are they the same for 68 also??
Aaron
68 Roadrunner 383/AT
69 Dart GT Conv. 383/AT
05 Dodge Ram 4x4 Cummins
06 GoManGo R/T Daytona #757
68 Coronet 440
Re: what is correct attach hardware for hood insert 69 GTX [Re: JohnRR] #1505349
09/21/13 05:46 PM
09/21/13 05:46 PM
colorado
a12superbee Offline
a12superbee  Offline
colorado
65$ for a set of 16. That is impressive.
I can't afford this. mark
Re: what is correct attach hardware for hood insert 69 GTX [Re: a12superbee] #1505350
09/22/13 03:34 PM
09/22/13 03:34 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I was looking for a picture of the part and that was what I found
