My Cousin has a problem with his dart since it was built 3 years ago we can not figure out! 1990 tbi 360 stock bottom end, edelbrock heads, comp cam with no fuel pump lobe, headers, air gap intake, edelbrock 750, MSD coil, stock 74 ignition box and distributor. Electric 3-5 psi fuel pump. Car backfires out the pipes when under full throttle, stumbles, and then roars back to life. Has 9 volts at the coil, have checked and set timing everywhere, adjusted valves a few times, can not get rid of it. Is the issue using a TBI block and cam and old ignition?
