440Source vale covers ? #1503971
09/18/13 05:43 PM
09/18/13 05:43 PM
Balt. Md
3
383man Offline OP
383man  Offline OP
Balt. Md
Wondering if anyone uses their cast aluminum valve covers and how you like them ? And do they seal up good ? Thanks , Ron
Re: 440Source vale covers ? [Re: 383man] #1503972
09/18/13 06:10 PM
09/18/13 06:10 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
They look like they come out of the same mold as the Indy ones !!!
Re: 440Source vale covers ? [Re: Stanton] #1503973
09/18/13 06:47 PM
09/18/13 06:47 PM
Balt. Md
3
383man Offline OP
383man  Offline OP
Balt. Md
Thats true as I want a cover without any logo on it so the 440Source covers should work for me. I want to use a cast aluminum cover to make sure I have no valve cover leaks as I can use the newer style gaskets with the cast covers. I plan to paint them orange and put the 426 SuperStock decals on them. Ron
Re: 440Source vale covers ? [Re: 383man] #1503974
09/19/13 02:41 PM
09/19/13 02:41 PM
Oklahoma City
Jwilli500 Offline
Jwilli500  Offline
Oklahoma City
I bought a set of these from Summit. Haven't had a chance to use them yet, but they appear to be pretty nice plus the price was right.
http://www.summitracing.com/parts/sum-440350/overview/make/dodge
Re: 440Source vale covers ? [Re: Jwilli500] #1503975
09/25/13 10:44 PM
09/25/13 10:44 PM
Balt. Md
3
383man Offline OP
383man  Offline OP
Balt. Md
Thanks the ones from Summit look like they might work. Ron
Re: 440Source vale covers ? [Re: 383man] #1503976
09/25/13 11:30 PM
09/25/13 11:30 PM
SE PA
Yellow Fever Offline
SE PA
I have these, they are nice and I like the hidden bolts.
http://www.ebay.com/itm/BBM-FABRICATED-A...325&vxp=mtr
Re: 440Source vale covers ? [Re: 383man] #1503977
09/25/13 11:43 PM
09/25/13 11:43 PM
Ron what are the best VC gaskets to get?
Re: 440Source vale covers ? [Re: RapidRobert] #1503978
09/25/13 11:52 PM
09/25/13 11:52 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
The blue ones from Moroso.
Re: 440Source vale covers ? [Re: Stanton] #1503979
09/25/13 11:58 PM
09/25/13 11:58 PM
Thank you!
Re: 440Source vale covers ? [Re: RapidRobert] #1503980
09/26/13 06:26 AM
09/26/13 06:26 AM
Queensland,Australia
T-bar Offline
T-bar  Offline
Ron I have their polished cast valve covers they have a nice machined gasket surface and mine don't leak. Glued the gasket on them with rtv and had them on and off a few times and there all good. They never came with breather holes or baffels.
Re: 440Source vale covers ? [Re: RapidRobert] #1503981
09/26/13 11:12 AM
09/26/13 11:12 AM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Give these a whirl for more durability and heat resistance.
https://board.moparts.org/ubbthreads/show...e=0#Post7855502
Re: 440Source vale covers ? [Re: roadhazard] #1503982
09/26/13 05:21 PM
09/26/13 05:21 PM
Balt. Md
3
383man Offline OP
383man  Offline OP
Balt. Md
Yellow Fever what kind of valve covers are they as they look good ? I figure since I have a nice flat head surface with my aluminum heads that if I got a V/C with a nice flat surface I could use the Moroso gaskets as the rubber coated ones with the metal insert in them should work great like that but they dont work to good with stock steel V/C's. Since I pull my covers at least once a year to adjust my valves I want to use a gasket that I can use over. But them other ones you guys showed me look good also. I figure with the cast aluminum covers and aluminum heads it would seal up very easy every time. Thanks , Ron
Re: 440Source vale covers ? [Re: 383man] #1503983
09/26/13 06:44 PM
09/26/13 06:44 PM
SE PA
SE PA
Not sure who makes them Ron but they have nice thick flanges and I used the steel core gaskets and they seal nice on my stealth heads. I'm very happy with them, here's another shot.
Re: 440Source vale covers ? [Re: Yellow Fever] #1503984
09/26/13 07:26 PM
09/26/13 07:26 PM
ILL
MLR426 Offline
MLR426  Offline
ILL
Something for everyone to take note of: If you use these valve covers with Big aluminum rockers you have to modify the rockers on the push rod side in order to get them to clear the inside of the cover. They have to be cut back by radius-ing the end of the rocker corners off or they will not bolt down and clear.
They are a very nice covers though, Indy gets them from the same importer as 440 source ?? Pro-Comp
MLR426 Performance Plus Cylinder Head
