Re: 440Source vale covers ?
[Re: roadhazard]
#1503982
09/26/13 05:21 PM
09/26/13 05:21 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
Yellow Fever what kind of valve covers are they as they look good ? I figure since I have a nice flat head surface with my aluminum heads that if I got a V/C with a nice flat surface I could use the Moroso gaskets as the rubber coated ones with the metal insert in them should work great like that but they dont work to good with stock steel V/C's. Since I pull my covers at least once a year to adjust my valves I want to use a gasket that I can use over. But them other ones you guys showed me look good also. I figure with the cast aluminum covers and aluminum heads it would seal up very easy every time. Thanks , Ron
[Re: Yellow Fever]
#1503984
09/26/13 07:26 PM
09/26/13 07:26 PM
Posts: 4,799 ILL
MLR426
ILL
Something for everyone to take note of: If you use these valve covers with Big aluminum rockers you have to modify the rockers on the push rod side in order to get them to clear the inside of the cover. They have to be cut back by radius-ing the end of the rocker corners off or they will not bolt down and clear. They are a very nice covers though, Indy gets them from the same importer as 440 source ?? Pro-Comp
MLR426 Performance Plus Cylinder Head
