Strange Spool Bearings #1503772
09/18/13 12:14 PM
09/18/13 12:14 PM
Seminole County FL to Plymouth...
Barry70GTX Offline OP
Do the Strange Dana 60 Spools use a special bearing or do the standard bearings work on them?
NMCA NSS 67 Coronet
Re: Strange Spool Bearings [Re: Barry70GTX] #1503773
09/18/13 12:26 PM
09/18/13 12:26 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Strange spools can use the standard bearing and race for regular Dana -60 housings,however a Strange S-60 housing must use a narrow race for the side adjusters
Re: Strange Spool Bearings [Re: B G Racing] #1503774
09/18/13 01:02 PM
09/18/13 01:02 PM
Thanks Bob. I'm scratching my head when I see "spool bearings" listed.
NMCA NSS 67 Coronet
Re: Strange Spool Bearings [Re: Barry70GTX] #1503775
09/18/13 01:13 PM
09/18/13 01:13 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Just check the brand and P/N s hopefully you will get a set made in USA,usually they are stamped China,Brazil,Alaska,Tiawan and others.
