want to 4 link my truck, anyone here do it? post pics!
#1503542
09/18/13 12:32 AM
09/18/13 12:32 AM
Posts: 2,682 Clinton Twp. Michigan
coronet1966d
im setting up the driveline angle with the new 6 speed and the way its lowered in the rear id like to scrap everything and 4 link it. show me some inspiration and where did you get the parts? I saw speedway motors has a kit Ladder bars vs 4 link? is a panhard bar needed? enlighten me
Re: want to 4 link my truck, anyone here do it? post pics!
[Re: BulletBob]
#1503545
09/18/13 03:27 AM
09/18/13 03:27 AM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
ladder bar = panhard bar, wishbone or a Watts link 4 link = diagonal link Alston Chassisworks or Art Morrisin also has both systems.. look at Morrisons site, there is a lot of good info there. A ladder bar system would take less construction than a 4 link system theres also 2 different types of 4 link 1 is the equal length drag race style 2 is the diagonal 4 link that somewhat resembles the GM suspension used on the Ce\hevelle/Malibus ect..
I am truckless..
[Re: 340SHORTY]
#1503546
09/18/13 11:37 AM
09/18/13 11:37 AM
Posts: 8,064 Iowa
76dodgeboy
Iowa
[Re: 76dodgeboy]
#1503547
09/18/13 05:15 PM
09/18/13 05:15 PM
Posts: 773 Crofton, Ky.
rattler
Crofton, Ky.
How about getting the parts from the junkyard? The new Ram trucks use coil springs, 4 link setup. And if you could find a R/T truck, you would have a 4:10 gear to boot.
1957 Dodge truck, Snakeskin Green with a little stroker motor. 1964 Plymouth Savoy wagon ( my new project)
[Re: rattler]
#1503548
09/18/13 05:25 PM
09/18/13 05:25 PM
Posts: 8,064 Iowa
76dodgeboy
Iowa
Bigger bolt pattern and Im pretty sure Wider rear end and totally different frame so alt of Hacking may need to be done to frame and box
[Re: BulletBob]
#1503550
09/18/13 09:52 PM
09/18/13 09:52 PM
Posts: 12,043 State of Confusion
hp383
Just a normal tag again
State of Confusion
Dont forget you can also do a simple ladder bar with leafsprings (Uses factory springs, so no locator bar needed)
This is a cheap, easy way to add more traction and lift.
Join the Penguin Liberation Front!! Stop the Hippo Occupation!
