66 Belvedere - Oil Leak #1503339
09/17/13 09:04 PM
09/17/13 09:04 PM
Northeast
edl Offline OP
edl  Offline OP
Northeast
seems to be coming from where the engine meets the transmission - figure this is a rear seal - is there a way to know for sure?
if it is, how is the seal replaced? - engine in car or does the engine need to come out?
thanks
Re: 66 Belvedere - Oil Leak [Re: edl] #1503340
09/17/13 09:39 PM
09/17/13 09:39 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
There are many places back there than can leak , 2 screw in plugs for the main galleys , the rear cam plug and the rear main seal. If I remember right this is a survivor , if it is and the engine is still factory original AND it's the rear main seal it's a ROPE SEAL , you will be pulling the engine to replace that .
Also don't discount GRAVITY , hemis can leak in a bunch of places above the bellhousing ... so I've read on the internet ... and gravity does it's thing.
Re: 66 Belvedere - Oil Leak [Re: JohnRR] #1503341
09/17/13 10:15 PM
09/17/13 10:15 PM
Northeast
edl Offline OP
edl  Offline OP
Northeast
thanks John - think this will be a case of wait, watch and top off!
