6.4L hemi #1503189
09/17/13 04:05 PM
09/17/13 04:05 PM
norway
aufles.mopar Offline OP
norway
Hi
what do i need to get a new 6.4L hemi run in my hot rod.i have used a 5.7 and a 6.1 but i understand that it is more work to get a 6.4L to run
1971 cuda and 1934 plymouth hotrod
Re: 6.4L hemi [Re: aufles.mopar] #1503190
09/17/13 04:21 PM
09/17/13 04:21 PM
norway
norway
Do i have to use the variable timing or is it enough not conecth those wires to it
Re: 6.4L hemi [Re: aufles.mopar] #1503191
09/17/13 04:25 PM
09/17/13 04:25 PM
Irving, TX
feets Online tonguue
Senior Management
feets  Online Tonguue
Senior Management
Irving, TX
Hi
You need a smaller picture of the engine.
- Stu Harmon
Re: 6.4L hemi [Re: feets] #1503192
09/17/13 05:10 PM
09/17/13 05:10 PM
norway
norway
Re: 6.4L hemi [Re: aufles.mopar] #1503193
09/17/13 05:11 PM
09/17/13 05:11 PM
Norrland, Sweden
Swedcharger67 Offline
Norrland, Sweden
A friend of mine is building a special based on the 2008 Challenger SRT-8 drivetrain.
His intention is to use the instrument panel as well as the engine management system. The current problem is how to disable airbags and all the other functions not needed.
- Do you know if the SRT-8 engine control can be manipulated?
My view regarding the variable valve timing is that you should try to use it if you can. I currently don't know how the control of it is done, so sorry cannot help you there.
That's a nice piece of engine you have there!
Martin, 67 Charger, 512 cui, E85, MegaSquirt MS3X sequential ignition & injection
Re: 6.4L hemi [Re: Swedcharger67] #1503194
09/18/13 11:52 AM
09/18/13 11:52 AM
norway
norway
nobody who know how to do?
Re: 6.4L hemi [Re: aufles.mopar] #1503195
09/18/13 12:28 PM
09/18/13 12:28 PM
Northeast
V
VincentVega Offline
VincentVega  Offline
V
Northeast
the cam phaser is required for drivability with the high compression of the 6.4. You will be in odd territory without it (pinging/knocking), and it might not even run on pump gas at all. I would try to run the entire package, or go another route
Looking for 1975 through 1978 B body 4 door sedan sheet metal or parts cars - monaco, fury, coronet. Please let me know
Re: 6.4L hemi [Re: VincentVega] #1503196
09/18/13 04:14 PM
09/18/13 04:14 PM
norway
norway
Hi
Thanks.
that was one of the same thing that i was thinking about
Re: 6.4L hemi [Re: aufles.mopar] #1503197
09/18/13 08:18 PM
09/18/13 08:18 PM
Omaha Nebraska
Brian_wo Offline
Brian_wo  Offline
Omaha Nebraska
I think the 6.4 is a VVT engine,now I have not kept up with those the past 8-12 months but last I knew people had not figured out how to put a VVT motor in a non VVT car,that being said maybe its not a big deal going in an old rod.
doing a 6.1 is easy,one call to hotwire and they will build a plug and play harness to make it work.
who is that guy?
Re: 6.4L hemi [Re: Brian_wo] #1503198
09/18/13 08:34 PM
09/18/13 08:34 PM
Tehachapi CA
MRBELV2 Offline
MRBELV2  Offline
Tehachapi CA
Modern Muscle Performance just came out with the 6.4 engine management system. Not cheap, but only option I know of. Rest of stuff is readily available.
