Steering column coupler lubricant. #1501936
09/15/13 06:14 PM
09/15/13 06:14 PM
Fremont, CA.
Topcat Offline OP
Topcat  Offline OP
Fremont, CA.
I just tore down my steering column over the week-end to restore.
When I took the end coupler that goes to the steering box apart; it had a thick gooey tar like stuff inside. I take it that they put that in there to help eliminate vibration coming up thru the column.
What do you recommend I replace it with?
Re: Steering column coupler lubricant. [Re: Topcat] #1501937
09/15/13 06:19 PM
09/15/13 06:19 PM
Kentucky USA
RR6BBL1969 Offline
RR6BBL1969  Offline
Kentucky USA
Not sure what lubricant they used from the factory but I would just about bet it was a wheel bearing grease from a tub. Yours is probably thick and gooey from drying out.
Re: Steering column coupler lubricant. [Re: RR6BBL1969] #1501938
09/15/13 06:24 PM
09/15/13 06:24 PM
IN
ahy Offline
ahy  Offline
IN
I filled mine with wheel bearing grease.
Re: Steering column coupler lubricant. [Re: ahy] #1501939
09/15/13 06:43 PM
09/15/13 06:43 PM
Kirkland, Washington
Pacnorthcuda Offline
Yep, me too on the wheel bearing grease.
