Use your safety gear correctly !! #15007
03/17/05 11:57 PM
03/17/05 11:57 PM
Boynton Beach, Fl
Rapid588 Offline OP
Rapid588  Offline OP
Boynton Beach, Fl
A good friend of mine that races footbrake class got into someones ANTIFREEZE when it overflowed their puke tank in the top end at the All Chevy show this weekend and even tho it was a very nasty wreck he went home to his wife and kids because he takes his safety equipment very seriously. He is a very experienced racer.....multi time track championships at 2 different tracks in the same year, and with this particular car had well over 4700 passes on it.....all his experience didn't help when his car started flipping......but what his experience did do was make sure that his harnesses are always pulled so tight that it's painful before he pulls into the water box.
One observation i made was related to the testing that Capt Nemo posted here about the latches failing and not the webs during his destruction testing.....my friend is about 6'3 and weighs around 260....if you look closely you will see the roll cage crumpled in, but it is the only area that was spared total destruction......he was very lucky!! I see a LOT of the dragster drivers have very loose belts so they can raise up out of their seats to turn around and see someone running them down.....a very dangerous practice at best!! One of our Moparts members (rapidus maximus) also had a very bad wreck but was able to tell us about it because his safety equipment was correctly used......... Guys and Gals.....be safe !!
Randy
93 Dodge Stealth - Supercharged 526ci Hemi
93 Dodge Daytona Top Sportsman injected 588 Hemi - plus a lil NOS
67 Hemi GTX (may the 4speed with you!)
Re: Use your safety gear correctly !! [Re: Rapid588] #15008
03/18/05 12:00 AM
03/18/05 12:00 AM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
That's a shamefull loss of a good car.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: Use your safety gear correctly !! [Re: amxautox] #15009
03/18/05 12:07 AM
03/18/05 12:07 AM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
Makes you stop to think... my harness is never really tight. That's an eye opener Glad he was OK.
Re: Use your safety gear correctly !! [Re: Rapid588] #15010
03/18/05 12:37 AM
03/18/05 12:37 AM
corpus christi,texas
dwdart Offline
dwdart  Offline
glad to here your friend is ok.
from those two pictures, it dosn't look like there is one good part left on the whole car.
that sure will make you think, how well do we use our safety equipment.
i guess it's good to get a little gut check every once in a while.
Re: Use your safety gear correctly !! [Re: Rapid588] #15011
03/18/05 02:33 AM
03/18/05 02:33 AM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
man what a shame, looks like it was a nice car...at least he's around to build another one. it may seem like a trivial thing but checking the overflow is something i do. for the most part we're not even supposed to run antifreeze, not that water wouldn't have had the same effect. antifreeze is some slimy stuff though.
Re: Use your safety gear correctly !! [Re: jamesc] #15012
03/18/05 06:55 AM
03/18/05 06:55 AM
You guys might want to stroll through this thread as well:
Losing One
Re: Use your safety gear correctly !! #15013
03/18/05 11:13 AM
03/18/05 11:13 AM
Down South
CaptNemo Offline
super gas
CaptNemo  Offline
super gas
Down South
Glad to hear that he went home that night.
OK guys, this and Rapidus's wreck are Wake Up Calls for the racers here. Both of these guys have a bunch of runs in their logbooks and still it happened to them. Both of these guys went home because their equipment functioned correctly. The cage protected them and their harnesses kept them in place in the seats.
This is precisly the reason I sell safety equipment and try to help the guys get the correct equipment and use it the right way. This why there are tech inspections and a two year life span on harnesses. This is why you shouldn't snivel about having to spend $50 to $75 to get a pair of harnesses re-webbed. If you can't afford that piece of life insurance, you shouldn't be racing.
Now do you want the cheapest 5 point harnesses and helmet available ??
Re: Use your safety gear correctly !! [Re: CaptNemo] #15014
03/18/05 11:54 AM
03/18/05 11:54 AM
NC
440Jim Offline
440Jim  Offline
NC
Sorry to hear about the accident. Glad the driver is OK.
Thanks for the reminder on the safety equipment and keeping the harness tight.
It is disturbing that another driver's life was threatened and his investment lost because of a radiator overflow. That is not suppose to happen. I do check my overflow bottle occassionaly and have never found anything except after the first heat/cool cycle when filling it. But it would be a good check before every run while sitting in the pits.
Re: Use your safety gear correctly !! [Re: 440Jim] #15015
03/18/05 03:13 PM
03/18/05 03:13 PM
Boynton Beach, Fl
Rapid588 Offline OP
Rapid588  Offline OP
Boynton Beach, Fl
I also check mine before and during a race.....also have a secondary puke tank with a vent on it after the first one just in case......also a believer in engine diapers, even if it's not required. You can barely see the aluminum recirculating one behind the secondary red one with the filter.....is there in case of head gasket or whatever failure......the large hose goes to my in car air condition system.
Re: Use your safety gear correctly !! [Re: Rapid588] #15016
03/18/05 04:07 PM
03/18/05 04:07 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I am one of the guy's that doesnt give the straps
that last tug before going into the water box, I
think I better start doing it, just for safety
sake. Sorry about your buddies car but I am glad
he walked away
Re: Use your safety gear correctly !! [Re: Rapid588] #15017
03/18/05 04:29 PM
03/18/05 04:29 PM
good advice, i used to see him at the track every race night. i'm glad he's okay. instead of "twice nuts" maybe the new car can be "3rd times a charm".
Re: Use your safety gear correctly !! #15018
03/18/05 05:09 PM
03/18/05 05:09 PM
Rochester, New York
GregY Online content
GregY  Online Content
Rochester, New York
I guess the lesson is: it CAN happen to you.
I am glad he is okay. That looked like a beautiful car, it's too bad.
Re: Use your safety gear correctly !! [Re: Rapid588] #15019
03/18/05 05:59 PM
03/18/05 05:59 PM
Mesa, AZ
Bill_T Offline
Bill_T  Offline
Mesa, AZ
What ET/MPH on that car?
This space not for rent.
Re: Use your safety gear correctly !! [Re: Bill_T] #15020
03/18/05 06:21 PM
03/18/05 06:21 PM
S.E. Michigan
cl440 Offline
cl440  Offline
S.E. Michigan
I will give my harness an extra tug from here on!!
Glad he's OK!!
Re: Use your safety gear correctly !! [Re: cl440] #15021
03/18/05 06:41 PM
03/18/05 06:41 PM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
Glad he's OK. To think my friend wonders why I want a full cage in a 12 second car. I'll take the extra life insurance please.
Re: Use your safety gear correctly !! [Re: AdamR] #15022
03/18/05 09:26 PM
03/18/05 09:26 PM
Cambridge Vt.
mark_gates Offline
mark_gates  Offline
Cambridge Vt.
This makes me glad I just ordered real racing seats and new wraparound harnesses that fits thru the seat instead of the old y-type harness that just flopped over the tops of my stock buckets. I never felt that secure with that setup, even tho it passed "tech". Glad the guy is OK, it's a shame about the car. One very expensive ball of junk.
Re: Use your safety gear correctly !! [Re: mark_gates] #15023
03/18/05 09:43 PM
03/18/05 09:43 PM
NC
DCM71cuda Offline
DCM71cuda  Offline
NC
Your belts need to be tight....and as short as possible. They will stretch 30% or more when loaded
Re: Use your safety gear correctly !! [Re: Bill_T] #15024
03/18/05 09:48 PM
03/18/05 09:48 PM
Boynton Beach, Fl
Rapid588 Offline OP
Rapid588  Offline OP
Boynton Beach, Fl
Bill_T , it was a mid 10 second pass at around 127 mph
Re: Use your safety gear correctly !! [Re: Rapid588] #15025
03/19/05 12:38 AM
03/19/05 12:38 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Another thing while we are on the subject of puke cans and safety. I am sure most of you have your puke cans in the front of the car, on one side or other of the radiator. That is the WORST PLACE IT CAN BE. Put it in the trunk and run a hose to it. If it does overflow, at least it won't leak directly under YOUR tires. This tip would not have saved the car in the above pics, but I have seen many it would have saved.
Monte
Re: Use your safety gear correctly !! [Re: Rapid588] #15026
03/19/05 03:36 AM
03/19/05 03:36 AM
Kansas City, Missouri
P
PaxtonedProCuda Offline
super street
super street
P
All I can say is that this devestated me. I made my friend with a 10 second car come over to look at it. This was "one in an unlikely" chance but it sure would suck to be the one. I am so glad he had a good cage and more so than he is alright. I feel terrible for his financial loss also. He is alive and can start again if that is any relief at all. Thanks for sharing!
