Re: Correct brackets for '70 340 power steering pump
[Re: JRepucci]
#1501483
09/15/13 10:28 AM
09/15/13 10:28 AM
Posts: 21,469 It's a dry heat
gtx6970
It's a dry heat
1970 340 uses a Federal pump just like the AAR-T/A's Axle package cars had a cooler.
Gonna have to dis-agree with this one.
I've seen to many small block cars with saginaw pumps to have been ' replacements '
Including my former 1970 Challenger 340 , everything on that car was dated correct for the car
[Re: ScottSmith_Harms]
#1501494
09/15/13 01:45 PM
09/15/13 01:45 PM
Posts: 27,471 So Cal
autoxcuda
So Cal
Curiously, this one is off of a 71 340 Challenger with an early Oct SPD as well. It looked VERY original, I cleaned it up for this pic.
*As a side note, all of these examples had correctly dated PS hoses, and the one with the cooler had a correctly dated cooler as well. This adds to the likelyhood that they haven't likely been changed, etc. but nothing is 100% certain without all of the history.
Those brackets were on a 70 up small block with aluminum water pump?
Looks like the same brackets on a cast iron setup.
