A ratchet shifter would probably be your best bet. But I would stay with the better known manufacturers, like Hurst and B&M. As mentioned, all are cable operated. just have to route the cable so there aren't any sharp turns or kinks and keep it away from the exhaust pipes.
Personally I use a Hurst 1/4 stick with my manual reverse pattern trans in my race car. Many years ago, I had a Hurst Auto-Stick II in my street car.
If you retain the automatic shift features, you will need to retain the kickdown linkages and brackets.
To mount the shifter to the floor, I used a shallow piece of channel (Home depot has it.) Cut to the length of the shifter, I drilled and welded nuts to the underside to bolt the shifter down and easy removal. Then welded the channel to the floor in a comfortable spot.
