727 tailshaft interchange #150125
11/13/08 11:59 AM
11/13/08 11:59 AM
Concord, NC
gearhead440 Offline OP
super street
super street
Concord, NC
I just picked up a BB 727 from a motor home with a short tailshaft. I have a BB and SB 727 and each has the long tailshaft. Is it possible to remove the short tailshaft and install the longer tailshaft and output shaft from either the BB or SB trans ?
Thanks.
Speed is only a question of money: "Just how fast do you want to go?"
Re: 727 tailshaft interchange [Re: gearhead440] #150126
11/13/08 12:05 PM
11/13/08 12:05 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Yes, However not all output shafts are the same. You may need to swap the gear sets along with the output shaft.
As far as the shafts and tail housing are concerned, they are interchangable between the big and small blocks.
Re: 727 tailshaft interchange [Re: WILD BILL] #150127
11/13/08 12:08 PM
11/13/08 12:08 PM
Concord, NC
super street
super street
Concord, NC
Thanks Wild Bill.
Re: 727 tailshaft interchange [Re: gearhead440] #150128
11/13/08 12:15 PM
11/13/08 12:15 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
On CRT's website John has a really good article on output shafts and pics of there differences.
If you can't find it I can link it when I get home
Re: 727 tailshaft interchange [Re: WILD BILL] #150129
11/13/08 12:32 PM
11/13/08 12:32 PM
Concord, NC
super street
super street
Concord, NC
Found the CRT site.
Re: 727 tailshaft interchange [Re: gearhead440] #150130
11/13/08 03:47 PM
11/13/08 03:47 PM
LOWELL IN
Q
QWK_ENUF Offline
QWK_ENUF  Offline
Q
LOWELL IN
call john after 5 pm cst and he will answer your questions in pers on
WAXER
Re: 727 tailshaft interchange [Re: QWK_ENUF] #150131
11/13/08 04:26 PM
11/13/08 04:26 PM
Florida STAYcation
dOc … Offline
The village idiot's idiot
dOc …  Offline
Florida STAYcation
EITHER the SB or BB tailshaft will work in your MH trans ... but you MUST use the output shaft from the standard long-shaft trans too.
Re: 727 tailshaft interchange [Re: gearhead440] #150132
11/14/08 05:16 PM
11/14/08 05:16 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
As stated, all of the standard length tailhousings will interchange but if the car is equipped with a factory console shift the tailhousing needs to have the boss on the bottom for the linkage support bracket; some year truck housings won't have the boss.
