SS Springs and correct hardware 65 B sits to Low!
#1501226
09/14/13 03:52 PM
09/14/13 03:52 PM
Posts: 926 MICHIGAN
BB65Barracuda
MICHIGAN
Anyone got a suggestion? The 65 Coronet 500 with SS Springs and Im using the top hole on the front mount. Still looks like it dragging a$$.
1957 Power wagon wm300 original 10.000 mile truck, 1964 dodge Polara Convertible numbers matching
Re: SS Springs and correct hardware 65 B sits to Low!
[Re: Andrewh]
#1501228
09/14/13 04:08 PM
09/14/13 04:08 PM
Posts: 926 MICHIGAN
BB65Barracuda
MICHIGAN
Oh Crap! I think your right! The problem is that an inch is still to low. Im looking for at least 2".
[Re: BB65Barracuda]
#1501229
09/14/13 05:16 PM
09/14/13 05:16 PM
Posts: 926 MICHIGAN
BB65Barracuda
MICHIGAN
Well, I went out and checked and I do have them in the lower holes! Still have the issue.
[Re: BB65Barracuda]
#1501230
09/14/13 05:23 PM
09/14/13 05:23 PM
Posts: 25,902 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Every early B that I put SS springs in sat way too high for my taste.
If it sits too low I'd say you have the wrong springs (can't handle the static weight). What are the spring numbers?
[Re: Joesixpack]
#1501233
09/15/13 12:10 AM
09/15/13 12:10 AM
Posts: 926 MICHIGAN
BB65Barracuda
MICHIGAN
I bought them from Mancini Racing they are 456 and 457 and the 079 front hanger brackets. I used the stock rear shackles. I will post pics tomorrow. They did lift the rear of the car a bit, to the top of the rim but I would like it a bit higher. I know what you mean though, I had them on my 65 barracuda and the car had that stinkbug stance. the A body sat too high, not the B body.
[Re: BB65Barracuda]
#1501234
09/15/13 12:59 PM
09/15/13 12:59 PM
John_Kunkel
Rio Linda, CA
The 456 and 457 should jack the ass end so high you need a ladder to get to the trunk. The 079 brackets are for '66 and later....might be the problem.
[Re: John_Kunkel]
#1501235
09/15/13 03:04 PM
09/15/13 03:04 PM
Posts: 4,384 Madison Wi
NTOLERANCE
Madison Wi
I am not all that familiar with the mancini brackets, but could they be in upside down?
079 brackets are for 64/65 cars according to their web site.
[Re: BB65Barracuda]
#1501239
09/15/13 06:07 PM
09/15/13 06:07 PM
NTOLERANCE
Madison Wi
Whats your shakle angle? Your car looks alot like my 65.....faded white, chips, a few dents, bits of rust.... Yours is a bit nicer though. Does it have two tone red guts?
[Re: NTOLERANCE]
#1501240
09/15/13 07:10 PM
09/15/13 07:10 PM
Posts: 926 MICHIGAN
BB65Barracuda
MICHIGAN
Shackle angle is fine, The interior is black. Ive seen couple 65's that sat about 2" higher in the back and I really like the look.
[Re: BB65Barracuda]
#1501241
09/15/13 07:15 PM
09/15/13 07:15 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
One possibility is that you have the front cranked up too high and it's sitting level?
Might want to double check your ride height, but looking at the pics it appears ok.
[Re: topside]
#1501243
09/15/13 09:42 PM
09/15/13 09:42 PM
Posts: 926 MICHIGAN
BB65Barracuda
MICHIGAN
The front end is at 24 3/4" to the lip on the front fender. If you look at the picture of the front of the car it is pretty low. The tag with the part numbers are still on the springs. The front segments are 20" all of the measurements are right. Like I have said, it is sitting lower than I prefer. Ive seen these cars with a good half of the upper part of the tire exposed. .
[Re: BB65Barracuda]
#1501245
09/16/13 02:35 AM
09/16/13 02:35 AM
Posts: 2,431 SK,Canada
gregsrt
SK,Canada
I have the same springs and hangers in my 66, front spring mount is in the bottom hole. I wish it was a bit higher too.
An association of men who will not quarrel with one another is a thing which has never yet existed, from the greatest confederacy of nations down to a town meeting or a vestry.
Thomas Jefferson
