Dr. Diff, B rear into E body question #1500782
09/13/13 10:20 AM
09/13/13 10:20 AM
Ky
jt4406 Offline OP
jt4406  Offline OP
Ky
Put a b body dana in my 70 challenger using Dr. Diff's offset hanger kit (kept the b body spaced spring pads on the rear) While trying to install the rear valance(dual exhaust cut out), I found the inner braces in the valance hit the rear shackles. Can I wriggle the valance around and make the braces clear, or will I have to trim them?
jess
Yeah, it's hopped up to over 160...
Re: Dr. Diff, B rear into E body question [Re: jt4406] #1500783
09/13/13 10:42 AM
09/13/13 10:42 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
If you have an OEM valance with exhaust cut-outs, you must trim the braces.
Re: Dr. Diff, B rear into E body question [Re: DoctorDiff] #1500784
09/13/13 10:46 AM
09/13/13 10:46 AM
BDW Offline
BDW  Offline
I found this out the hard way too
Re: Dr. Diff, B rear into E body question [Re: BDW] #1500785
09/13/13 11:02 AM
09/13/13 11:02 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
You can also install the shorter shackles I produce for clearance on Barracuda models, but this will lower the car.
