I have been trying to understand how to tune with different ignition coils and trying to understand what different turns ratio's do and lower and higher inductance, peak current, primary resistance and secondary resistance. I'm told that this all matters and some how I cant make sense of it all.
I'd rather have a coil that's going to get the most flame to the spark plug, and it doesn't have to be able to do it at extremely high rpm's because I run a 360 magnum and hardly ever go past 6000 rpm.
I am running a crane cams hi-6 cd ignition and a crane cams lx91 coil.
I wanted to share the specs of this coil with you guys to see if you could tell me if this coil is what I want, or if there is better performance to be had. the primary resistance is 0.420 ohms the secondary resistance is 3.5k ohms the turns ratio is 54:1 the inductance is 5.6mh the peak current is 100ma and the spark duration is 2,800us. I run my plugs at a .045 gap. Is this coil the right coil for what i'm doing? This engine is all street and more of a torque engine then a high rpm screamer. I'm just curious if playing around with different coils would yield any positive results, or if this coil is the right one for what I do with it.
