Cheaper but good alternative to Dynamat? #1500271
09/11/13 10:07 PM
09/11/13 10:07 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Hi!
I need to insulate a car's flor against road noise, exhaust noise and also insulate it so that the heat radiatiion from the headers and 3" exhaust isnt unbeareable inside the car.
I know Dynamat does the trick, but it is expensive.
Looking for a cheaper alternative that will work just as good. What product would you guys reccomend?
Looking for the best bank for the buck.....I see Summit has some alternatives, wonder how good they are.
Re: Cheaper but good alternative to Dynamat? [Re: domingo] #1500272
09/11/13 11:43 PM
09/11/13 11:43 PM
Grand Rapids,Minnesota
65belvedere Offline
65belvedere  Offline
Did you check Dynamat prices at Amazon?
Re: Cheaper but good alternative to Dynamat? [Re: 65belvedere] #1500273
09/11/13 11:51 PM
09/11/13 11:51 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I bought FatMat from Amazon. Pretty cheap compared to Dynamat or Hushmat. It was the same .080 thickness and unlike some of the cheaper stuff, had no asphalt smell.
Some guys use some roofing type stuff from home improvement stores. I didnt want to go that route. The smell would make summer driving less than pleasureable.
Re: Cheaper but good alternative to Dynamat? [Re: Kern Dog] #1500274
09/12/13 12:16 AM
09/12/13 12:16 AM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
I will check that out....thanks!!!
Re: Cheaper but good alternative to Dynamat? [Re: domingo] #1500275
09/12/13 12:20 AM
09/12/13 12:20 AM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
How many square feet did it take to do your floors????
Re: Cheaper but good alternative to Dynamat? [Re: domingo] #1500276
09/12/13 12:30 AM
09/12/13 12:30 AM
Vancouver, BC, Canada
rtriv Offline
rtriv  Offline
I looked into this a bunch and found pretty good reviews on RAAMaudio. I got the RAAMat and Ensolite combo and they seem like good products and laid down nicely. Haven't run the car yet so can't comment on the performance.
http://www.raamaudio.com/
Re: Cheaper but good alternative to Dynamat? [Re: rtriv] #1500277
09/12/13 03:04 AM
09/12/13 03:04 AM
Santa Cruz, California
Lefty Offline
Lefty  Offline
I use Fat Mat or Hush Mat and get the 100sq/ft deal. Used to be $100, now it's around $130
Re: Cheaper but good alternative to Dynamat? [Re: Lefty] #1500278
09/12/13 10:44 AM
09/12/13 10:44 AM
British Columbia
chrisf Offline
chrisf  Offline
British Columbia
I se b-quiet happy with their product. they make a bunch of different sound deadeners not just the butyl backed stuff.
Re: Cheaper but good alternative to Dynamat? [Re: chrisf] #1500279
09/12/13 12:08 PM
09/12/13 12:08 PM
crlush Offline
crlush  Offline
Check out Peel and Seal from Lowe's home improvement store, I used it on my convertable and worked excellent, looks same as dynamat but in a roll, the rolls are only 6-8" wide but I don't think it really matters. its made for moble or rc trailer roofing repair, but if you go to Lowe's website and read the reviews I think everyone says how good it works for automotive sound and vibration deadining. Not shure if its better than dynamat but it made a heck of a differance on my ride plus its a third of the price.
Re: Cheaper but good alternative to Dynamat? [Re: crlush] #1500280
09/12/13 02:29 PM
09/12/13 02:29 PM
Omaha, Nebraska
Scott Carl Offline
Scott Carl  Offline
Omaha, Nebraska
Re: Cheaper but good alternative to Dynamat? [Re: 65belvedere] #1500281
09/12/13 07:52 PM
09/12/13 07:52 PM
central P.A.
HEMIDOG 70 Offline
HEMIDOG 70  Offline
central P.A.
I did that, then had Jegs price match the Amazon price. The Amazon price was much lower than Jegs but they matched it. I bought it from Jegs because they had it in stock and ship very quickly.
Re: Cheaper but good alternative to Dynamat? [Re: domingo] #1500282
09/12/13 10:40 PM
09/12/13 10:40 PM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
My order of 100 sq ft was more than enough. I did the floor from the pinch weld on the firewall to the axle hump. I put sections on the insides of the doors against the outer door skins. Some went in the quarter panels between the doors and wheel tubs. I did NOT pull the headliner to put it there. I had enough left over to do 60% of my Brother in laws Duster floor.
Re: Cheaper but good alternative to Dynamat? [Re: crlush] #1500283
09/13/13 08:59 AM
09/13/13 08:59 AM
n.e. pa.
65rbdodge Offline
65rbdodge  Offline
n.e. pa.
I just bought 2 rolls of this yesterday, it was about $20 per roll and is 9"x33'
Re: Cheaper but good alternative to Dynamat? [Re: 65rbdodge] #1500284
09/13/13 09:13 AM
09/13/13 09:13 AM
BDW Online content
BDW  Online Content
I'm curious what the Lowes stuff looks like. Sounds like a good deal, $20/25 sqft compared to $30 or more for the "automotive" stuff.
Re: Cheaper but good alternative to Dynamat? [Re: BDW] #1500285
09/13/13 10:19 PM
09/13/13 10:19 PM
crlush Offline
crlush  Offline
looks the same as dynamat (sticky rubber with aluminum foil on one side). I dont know what the difference is but for the money I experienced a big difference in noise control after installing it on my floors.
Re: Cheaper but good alternative to Dynamat? [Re: crlush] #1500286
09/13/13 10:26 PM
09/13/13 10:26 PM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
I read here and elsewhere that the home improvement store stuff smells like roofing tar. If it doesn't, I may consider this in future builds.
Re: Cheaper but good alternative to Dynamat? [Re: Kern Dog] #1500287
09/14/13 12:38 AM
09/14/13 12:38 AM
rtriv Offline
rtriv  Offline
Yes, I believe the cheap home depot stuff is asphalt based where as the more expensive stuff is butyl based.
Re: Cheaper but good alternative to Dynamat? [Re: rtriv] #1500288
09/14/13 02:04 AM
09/14/13 02:04 AM
BDW Online content
BDW  Online Content
I went to Lowe's, the Peel n Seal is $98 for 100 sqft.
That's a pretty good deal.
Wish I knew if it smells like tar, that would be bad.
Re: Cheaper but good alternative to Dynamat? [Re: BDW] #1500289
09/14/13 08:44 AM
09/14/13 08:44 AM
crlush Offline
crlush  Offline
I couldn't smell anything after install, if you put the roll up to your face you can smell it a bit but it is not overwhelming.
Re: Cheaper but good alternative to Dynamat? [Re: crlush] #1500290
09/14/13 12:40 PM
09/14/13 12:40 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
Just search "sound deadener" on e bay, there are hundreds of sellers, the Butyl rubber is more efficient and less smelly- but costs more.
