Re: Cheaper but good alternative to Dynamat?
[Re: Kern Dog]
#1500274
09/12/13 12:16 AM
09/12/13 12:16 AM
Posts: 9,670 Lima, Peru
domingo
EL Master
EL Master
Lima, Peru
I bought FatMat from Amazon. Pretty cheap compared to Dynamat or Hushmat. It was the same .080 thickness and unlike some of the cheaper stuff, had no asphalt smell. Some guys use some roofing type stuff from home improvement stores. I didnt want to go that route. The smell would make summer driving less than pleasureable.
I will check that out....thanks!!!
[Re: crlush]
#1500280
09/12/13 02:29 PM
09/12/13 02:29 PM
Posts: 1,568 Omaha, Nebraska
Scott Carl
Omaha, Nebraska
Check out Peel and Seal from Lowe's home improvement store, I used it on my convertable and worked excellent, looks same as dynamat but in a roll, the rolls are only 6-8" wide but I don't think it really matters. its made for moble or rc trailer roofing repair, but if you go to Lowe's website and read the reviews I think everyone says how good it works for automotive sound and vibration deadining. Not shure if its better than dynamat but it made a heck of a differance on my ride plus its a third of the price.
[Re: 65belvedere]
#1500281
09/12/13 07:52 PM
09/12/13 07:52 PM
Posts: 1,913 central P.A.
HEMIDOG 70
central P.A.
Did you check Dynamat prices at Amazon?
I did that, then had Jegs price match the Amazon price. The Amazon price was much lower than Jegs but they matched it. I bought it from Jegs because they had it in stock and ship very quickly.
[Re: domingo]
#1500282
09/12/13 10:40 PM
09/12/13 10:40 PM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
How many square feet did it take to do your floors????
My order of 100 sq ft was more than enough. I did the floor from the pinch weld on the firewall to the axle hump. I put sections on the insides of the doors against the outer door skins. Some went in the quarter panels between the doors and wheel tubs. I did NOT pull the headliner to put it there. I had enough left over to do 60% of my Brother in laws Duster floor.
[Re: crlush]
#1500283
09/13/13 08:59 AM
09/13/13 08:59 AM
Posts: 3,920 n.e. pa.
65rbdodge
n.e. pa.
I just bought 2 rolls of this yesterday, it was about $20 per roll and is 9"x33'
