440 vibration issues #1499816
09/10/13 08:04 PM
09/10/13 08:04 PM
South San Francisco, Californi...
MidPenMopar Offline OP
Looking for fun? Keep looking
Hey guys I have a buddy who has a 68 charger with a 727 automatic. He swapped the 383 for a 440 and since the new engine was installed it has a constant vibration that seems to be coming from the engine or transmission. It happens all the time even in park so we know its not the driveshaft or rearend.
Any ideas on where to start looking to cure the problem?
Thank you
Stu
Re: 440 vibration issues [Re: MidPenMopar] #1499817
09/10/13 08:18 PM
09/10/13 08:18 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Wrong balancer, improper balance of the crank.rods..
I am truckless..
Re: 440 vibration issues [Re: 340SHORTY] #1499818
09/10/13 08:38 PM
09/10/13 08:38 PM
Ok I was thinking the harmonic balancer would be the easiest place to start?
Re: 440 vibration issues [Re: MidPenMopar] #1499819
09/10/13 08:57 PM
09/10/13 08:57 PM
San Francisco Ca
SCATPK Offline
SCATPK  Offline
San Francisco Ca
Sounds like a converter issue to me.
Re: 440 vibration issues [Re: SCATPK] #1499820
09/10/13 09:02 PM
09/10/13 09:02 PM
Hey Herb, do you know of any way to tell if it's the wrong convertor without taking the transmission apart?? I know they swapped out the stock one for a 2900 stall.
Re: 440 vibration issues [Re: MidPenMopar] #1499821
09/10/13 09:07 PM
09/10/13 09:07 PM
NEW HAMPSHIRE AND MAINE
BIGSTROKER Offline
BIGSTROKER  Offline
If it's a cast crank 440 you need the external balancer and add the weights to the converter
Re: 440 vibration issues [Re: MidPenMopar] #1499822
09/10/13 09:08 PM
09/10/13 09:08 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
383 and 440 use the same converter.. Does he have any history on the 440?
I am truckless..
Re: 440 vibration issues [Re: MidPenMopar] #1499823
09/10/13 09:11 PM
09/10/13 09:11 PM
BIGSTROKER Offline
BIGSTROKER  Offline
If it's a cast crank 440 it is externally balanced
that being said you need the cast crank balancer "it has an offset weight on it" and you need to add the weights to the converter
they sell the weights and templet and you just weld them in place
Re: 440 vibration issues [Re: BIGSTROKER] #1499824
09/10/13 09:17 PM
09/10/13 09:17 PM
Thanks guys I will pass this info along!!
Re: 440 vibration issues [Re: MidPenMopar] #1499825
09/10/13 11:01 PM
09/10/13 11:01 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Yep, sounds like a external balanced engine without the counter balance weight. Oh by the way, don't run it till you get the weights on or you'll be doing a rebuild.
Re: 440 vibration issues [Re: rowin4] #1499826
09/10/13 11:04 PM
09/10/13 11:04 PM
He has been driving the car like this for years unfortunately.
Re: 440 vibration issues [Re: MidPenMopar] #1499827
09/10/13 11:26 PM
09/10/13 11:26 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Thank you
Stu
I'll tell you a short story, gleam from it, what you will...I purchased a vehicle several years ago from a mechanics shop, they had swapped out the old engine, for a low mile replacement, and of course there was a swapping of engine/transmission components to complete the swap, but now the vehicle had an annoying vibration, the ASE mechanics tried every approach of diagnoses, threw part after part at it...finally decided to unload it "as is"...I was interested in it, and of course queried all the ASE mechanics that worked on it, as to what was done, used, etc....the vehicle ran "ok", but had an annoying vibration at idle, in or out of gear, and at any speed cruising...I got it home, of course I started with the basics before tearing into dampners, converters, etc,....about 20 minutes into a general look over, I saw that the plug wires on cylinders 2 and 4 were crossed, after merely swapping the 2 wires, all was well in the world....although the ASE mechanic didn't like later hearing about the "quick-cure" to the vehicles so-called "problem" as he was fond of the vehicle and didn't really want to sell it, but the vibration issue couldn't be resolved, and his frustration with it, hastened it sale,...so start with the basics, and confirm them, before chasing ghosts
Mike
P.S....I lied, the story was a little long
Re: 440 vibration issues [Re: DAYCLONA] #1499828
09/10/13 11:57 PM
09/10/13 11:57 PM
Mike
Yep Mike that's a good idea, that has just been done. The fuel and ignition system has been gone through thoroughly in the last few days to make sure those were not an issue.
The car runs fine, just has a constant vibration emanating from it all the time.
Re: 440 vibration issues [Re: MidPenMopar] #1499829
09/11/13 10:40 AM
09/11/13 10:40 AM
U.S.S.A.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
U.S.S.A.
Mike
Stu first thing to do is get the info off he ID pad oup top in front of the intake , this will tell us what year engine the guy is working with.
The bad is he has been driving it like this for years ... STUPID ... he may have done some damage that may only be fixed by tearing into the engine. The 383 in my Dart has a vibration that was caused by an imbalanced flywheel , it was run like that for YEARS , miles I'm not sure how many , I recently had the dampner checked for balance , it's ok , the engine still has a vibration, as no it's not crossed wires
Re: 440 vibration issues [Re: JohnRR] #1499830
09/11/13 11:11 AM
09/11/13 11:11 AM
That would tell if the engine had a steel or cast crank correct??
Re: 440 vibration issues [Re: MidPenMopar] #1499831
09/11/13 11:16 AM
09/11/13 11:16 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
Yes, the 73 or so and newer 440's had cast cranks which does not mean that someone could not have updated to an internal or external balance steel crank either.
Re: 440 vibration issues [Re: MidPenMopar] #1499832
09/11/13 11:22 AM
09/11/13 11:22 AM
rowin4 Offline
rowin4  Offline
Or it could be a 440 6 pac engine with a steel crank , those were externally balanced engines also. Police car engines [ 440's ] back in the the day also had the 6 pac rods and pistons . Could be one of those engines. Run a scope down the plug hole and see what the top of the piston looks like.
Re: 440 vibration issues [Re: MidPenMopar] #1499833
09/11/13 01:22 PM
09/11/13 01:22 PM
dogdays Offline
dogdays  Offline
Let's not get complicated here, the answer is very simple. Discussions of rod and/or piston weight muddy the water.
A '68 Charger 383 was internally balanced, so the converter is neutral balanced.
A 440 at this stage in life is as likely to have a cast crank as a forged one. In my experience, if one is looking for a decent used 440 the engine found will most likely have a cast crank. This is because the later 440s were not very high performance engines and the early ones have been hot-rodded preferentially over the years, making them scarcer.
Look at the Engine ID pad under the distributor. It'll tell you everything about how the engine was built. Dollars to doughnuts, there will be a letter "E" stamped somewhere on the pad. That "E" stands for cast crank.
I am now assuming the engine is a cast crank 440 that was swapped into the Charger in a simple unbolt-bolt manner. In this case the 383 torque converter was used with the standard MOPAR flexplate. Here is your problem.
The cast crank 440 requires a certain amount of external balance on either end of the engine. Assuming again that the harmonic damper was not disturbed, the rear end of the crank is now unbalanced and vibrates. A weight must be added to the rear of the crank.
Chrysler did this by welding weights on the converter.
Your friend can do it by swapping his stock flexplate with a special unbalanced flexplate. Converter stays as before.
B&M used to be the only ones who made this unbalanced flexplate, I think others do now, too.
Assuming again that the car was not a drag racer or daily driver, and it didn't see a lot of miles, the rear main bearing is probably OK, at least good enough to let the owner simply swap in the imbalanced flexplate and keep driving the car.
R.
Get the Engine ID number and post it. There are a few other possibilities that are not so likely, but the ID number will allow the Sherlocks here to ferret them out.
Re: 440 vibration issues [Re: dogdays] #1499834
09/11/13 04:27 PM
09/11/13 04:27 PM
MICHIGAN
BB65Barracuda Offline
MICHIGAN
Possiably, As long as the motor was never rebuilt.
The numbers on the block will tell you what SHOULD be, not necessarily what is. I guess it could be another starting point.
The only way to tell if it is a forged or cast crank is from the casting lines on the throws.
You can also install the wrong Ba lancer on ether.
1957 Power wagon wm300 original 10.000 mile truck, 1964 dodge Polara Convertible numbers matching
Re: 440 vibration issues [Re: BB65Barracuda] #1499835
09/11/13 07:45 PM
09/11/13 07:45 PM
Thank you all for the great information! I will pass it all along to him.
