Big block power steering oil cooler #1499780
09/10/13 06:06 PM
09/10/13 06:06 PM
Lee Co. Fla.
5carguy Offline OP
5carguy  Offline OP
Lee Co. Fla.
I have a cooler with a date of 1689.This is mid June 1969.Is this an A12 cooler?What else would have used this? As allways TIA.
Re: Big block power steering oil cooler [Re: 5carguy] #1499781
09/11/13 12:38 AM
09/11/13 12:38 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Is there another date on it?
1689 = Tuesday 6/17/69
Saginaw power steering coolers would be used on A12 cars and any '70-'71 383/440 B & E-bodies with an axle package (possibly other combinations, also ).
Re: Big block power steering oil cooler [Re: 5carguy] #1499782
09/11/13 10:07 PM
09/11/13 10:07 PM
Stuart FL
mercman1 Offline
mercman1  Offline
Stuart FL
Power steering cooler was use on a "max cooling package" when the car had 3.54/3.55 or lower rear end gears. My 69 GTX with "max cooling" and 3.55 gears has the cooler you show. My 2nd 69 GTX with 22 inch radiator and 3.23 gears does not.
Re: Big block power steering oil cooler [Re: mercman1] #1499783
09/11/13 10:54 PM
09/11/13 10:54 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
An "axle package" was orderable ..... "Max cooling" was not.
Where was your GTX built & what's its SPD?
Re: Big block power steering oil cooler [Re: 6bblgt] #1499784
09/11/13 11:26 PM
09/11/13 11:26 PM
Stuart FL
mercman1 Offline
mercman1  Offline
Stuart FL
Car was built in Los Angeles on Halloween of 68. (A31)
