Re: Cam and roller Lifter suggestions
[Re: relax383]
#1499530
09/11/13 04:02 PM
09/11/13 04:02 PM
Posts: 31,030 Oregon
AndyF
My 70 RR is almost finished. have a 440 engine topped with edelbrock heads and a six pack setup. I want to swap in a hyd roller cam. I want torque to be about 475-500. Any suggestions? Also what roller lifters do you guys recommend?
Here is an article from the Tech Archives (always a good place to look first) This engine is a big block with Edelbrock heads and a Comp hyd roller cam. It should answer most of your questions.
http://www.popularhotrodding.com/tech/1007phr_big_block_mopar_engines/
[Re: 1967Valiant]
#1499531
09/11/13 04:09 PM
09/11/13 04:09 PM
Guitar Jones
Other than I tune on some of the fastest grudge cars around guess nothing.
Man reading comprehension on the net has not gotten any better has it?
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: AndyF]
#1499534
09/11/13 04:32 PM
09/11/13 04:32 PM
Posts: 427 Sweden
Mopar Guy
Sweden
Andy i dont like to brag but my engine is at least as powerfull as that one on 11,6 comp ratio and six pack set up !
[Re: Mopar Guy]
#1499535
09/11/13 05:34 PM
09/11/13 05:34 PM
Posts: 5,160 Texas
dannysbee
Texas
Patrick unless your engine and the engine in the article were on the same dyno , on the same day you really don't know if you are making more power. I don't think Andy was trying to one up you, just giving you some comparative information.
Getting old just means you were smarter than some and luckier than others.
[Re: dannysbee]
#1499537
09/11/13 06:21 PM
09/11/13 06:21 PM
Posts: 1,212 Canton, Ohio
Crazy68Dart
Canton, Ohio
So, is the issue with hydraulic lifters, when run on too aggressive a lobe, they self destruct? The internals get damaged in some way? Is this cause by the lifter, more likely with a roller lobe, bouncing out of control to the pushrod location. So, "bottoming out" the plunger for lack of a better description and damaging the lifter. Could something like a rev kit aid with a hydraulic roller setup? Make sure the lifter is well controlled while allowing the valve spring to better handle the push rod, rocker, valve, etc.? How much does oil pressure affect the life of a hydraulic lifter? Low(er) oil pressure combined with an out of control lifter, bad combo? Just thinking out loud.
383, Hemi 4-Speed, AlterKtion, D60
[Re: relax383]
#1499541
09/11/13 07:07 PM
09/11/13 07:07 PM
Posts: 2,091 Delray beach, Florida
Performance Only
I've used most of the different brands of hydraulic roller lifters on the market and have pretty good success with all of them. I think you need to pay close attention to cleanliness first off. Any debris no matter how small will keep the lifters from working properly. After that a lot depends on the weight of the valve train and the rpm you feel you want to run at. With that being said, spring pressures and spring rates need to be looked at very closely. Not enough spring and you will damage the lifter, too much spring and you'll damage the lifter. too much pre-load and the lifters try to pump up, causing the valves to stay open at higher rpm's. not enough preload and the pushrods will hammer the plungers and destroy the lifters. If you do your homework, or deal with a reputable shop, you have a far better chance of getting it right the first time. As far as the torque number you listed, you should be able to easily hit that number and more if you want to as long as the rest of the combination is in order. Okay, back to the Holiday Inn Express I go now.
machine shop owner and engine builder
[Re: Guitar Jones]
#1499542
09/11/13 07:53 PM
09/11/13 07:53 PM
Posts: 5 central, fl
turboduster
central, fl
Are we related? Lmao. I'm pretty sure I've seen him riding in the back of the farm truck. At least the dog rides in the front.
[Re: 1967Valiant]
#1499547
09/11/13 08:29 PM
09/11/13 08:29 PM
turboduster
central, fl
Yep all those are mine! Thanks for finding them!
Lol. You're a good sport.
[Re: turboduster]
#1499548
09/11/13 09:39 PM
09/11/13 09:39 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
The Cranes MUST be good since they cost about $750. Biggest problem I think is just most Mopars have a heavy valvetrain. Whatever you do stay away from Comps HR lifters. Morel has 2 grades of them, find a dealer for them and get the better of the 2. Use 11/32 valves and titanium retainers. There was a guy I read that basically set lash on the Morels by bottoming the plunger out completely then backing off like a 1/4 turn and claimed 7500 rpm on a BB Mopar. Whatever, it would be a potentially expensive experiment.
Mopar to the bone!!!
