I weld the advance slots up on the stock non adjustable distributor so I can have 12 to 16 degrees initial timing at a low idle, 600 to 800 RPM and then have a total of 34 to 36 on Mopar BB. All the SB Mopars I help tune and race with iron heads seem to like 30 to 32 degrees total. If you take that distributor apart you should see a number stamped onto the top part of the distributor that the rotor fits onto and the advance weight pins ride in to make the mecahincal advance
It should read between 10 and 14, those are the distributor degrees, not crankshaft degrees. Distributor degrees are twice as much as the crankshaft degrees so that means if the number is 12 you have 24 degrees of mechanical advance
if it is stamped 12 distributors degrees and you want to have 32 degrees total due the math and shorten up that slot so you get what you want, IE 14 to 16 degrees initial timing and 7 degrees mechanical equal 14+14=28, 16+14=30, 18+14=32
Let us know what you do
