Wing strip color -Daytona #149931
11/12/08 09:05 PM
11/12/08 09:05 PM
The Historic Hudson Valley
MONC Offline OP
MONC  Offline OP
How do you tell what the original wing stripe color should be on a Daytona?
Is it on the fender tag?
Should it match the interior?
Re: Wing strip color -Daytona [Re: MONC] #149932
11/13/08 01:19 AM
11/13/08 01:19 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
It'll be on your build sheet....in the stripe "box"
V8X......Black
V8W......white
V8R......Red
As far as matching the interior, it may or may not, the interior choice wasn't a key to matching the tailstripe
Re: Wing strip color -Daytona [Re: DAYCLONA] #149933
11/13/08 03:04 AM
11/13/08 03:04 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
AFAIK all '69 500s & Daytonas are coded V88 - "stripe delete".
Re: Wing strip color -Daytona [Re: 6bblgt] #149934
11/13/08 12:30 PM
11/13/08 12:30 PM
Farmington, CT
KISSAlien Offline
KISSAlien  Offline
Farmington, CT
I agree. I think the actual color depended on car and interior color. I'm pretty sure either the winged warriors or aero warriors sites had an article about it.
Re: Wing strip color -Daytona [Re: KISSAlien] #149935
11/13/08 02:34 PM
11/13/08 02:34 PM
Wisconsin
Aero426 Offline
Aero426  Offline
Wisconsin
Have you looked inside the trunk at the side marker area? Sometimes remnants of the old stripe will be found where it was tucked inside the sidemarker.
Please PM me the last six digits of the VIN and I will see if we have anything on the car in the database.
Re: Wing strip color -Daytona [Re: 6bblgt] #149936
11/13/08 06:01 PM
11/13/08 06:01 PM
S.I. N.Y.
1MYTGTX Offline
1MYTGTX  Offline
S.I. N.Y.
I concur.....the stripe code was never on the tag or BS
AFAIK there is no "real" way of telling the original stripe color without remnants of the original stripe. Most white interior cars had a white strips that I have seen....that rule is not golden though.
Quote from factory literature....
Special stripe will be added in conversion if desired, color of stripe, Red, White or Black, or "Omit Stripe" instruction must be provided by Dodge Plant Distribution to Modification Company
1MYTGTX
Re: Wing strip color -Daytona [Re: 1MYTGTX] #149937
11/13/08 08:17 PM
11/13/08 08:17 PM
MONC Offline OP
MONC  Offline OP
No kidding?
Guess the window sticker would be no better.
So what stops someone from changing the color of the stripe when restoring the car? ( one reason I asked should the interior match the stripe).
Re: Wing strip color -Daytona [Re: Aero426] #149938
11/13/08 08:22 PM
11/13/08 08:22 PM
MONC Offline OP
MONC  Offline OP
Doug, how about this one
http://cgi.ebay.com/ebaymotors/ws/eBayIS...em=300272690087
Re: Wing strip color -Daytona [Re: MONC] #149939
11/13/08 10:11 PM
11/13/08 10:11 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I coulda swore it was on the BS,......I looked a couple of Tona' BS's tonight and yes...V88 stripe delete for the initial line build
I did find Galens list of wing/color body/color interior/color combos.....MONC
That F6 Tona'....your interested in, Galen has 43 Tona's with that F6 paint option
Seems that the F6 with white wing is in the majority are far as THAT color combo.......according to Galen, that color/stripe option would be in the minority with a green interior, in the majority with a white interior, or in the minority with a black interior
Re: Wing strip color -Daytona [Re: DAYCLONA] #149940
11/13/08 10:22 PM
11/13/08 10:22 PM
MONC Offline OP
MONC  Offline OP
So statistically possible, but not probable it came from factory with white stripe and black interior, correct?
Re: Wing strip color -Daytona [Re: MONC] #149941
11/14/08 11:09 AM
11/14/08 11:09 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Statistically possible with Ma'Mopar yes......according to Galens list.......plus we've all seen our share of odd color combos.....like I said earlier, I don't believe interior color had a controlling choice in stripe color,....you have cars like Bill Cards B5 with B5 interior and F8 with F8 interiors, colors on the stripe were limited to red, black and white, and Chrysler did "frown" on some oddball combos.........I don't think you see F8/F8 with a red stripe......but black or white, Yes!.....I have seen in person an original TX9 with white interior and red wing.......knock out combo by the way!......I've only seen ONE stripe delete Tona' in person, the built sheet had no remarks in the stripe box, car was in original paint, no signs of any decal ever,......but the most convincing document from the original owner, was a scaloped and dated old Kodac photo the owner took the day he purchased it new off the lot,.....the main foucas of the pic, wasn't the car, so much, but his young daughters posing with the car,....luckly the rear tail and wing are clearly ID'ed as being body color!!......car is currently under going resto, 34,000 original miles, sitting garaged, since 72
