Re: 1988 Ram transmission?
[Re: newportrider]
#1499308
09/09/13 08:51 PM
09/09/13 08:51 PM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
Auto = 904 727 2x stick OD833 NP 435 4x 727 if auto NP435 if a stick
I am truckless..
[Re: 340SHORTY]
#1499309
09/09/13 09:09 PM
09/09/13 09:09 PM
Posts: 12,043 State of Confusion
hp383
Just a normal tag again
State of Confusion
You can put a 518 in there! Fairly simple instal with minor fabrication, or donor parts. Plus side is you get the overdrive, and lockup features (if you use a lockup 518). Down side is you have to do some driveshaft mods. But that overdrive really helps if you do much driving over 45mph.
Join the Penguin Liberation Front!! Stop the Hippo Occupation!
[Re: 76dodgeboy]
#1499314
09/10/13 01:33 PM
09/10/13 01:33 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
My '87 with 318 2 barrel has a 727 followed by a 8.25 diff. I have a narrowed Dana 60 I am going to install and will replace the 727 with a small block OD. I want one that is non-lockup and manually controlled OD (dash switch). My question is what trans would be best and how do I identify it? I know I will need to shorten the drive shaft with the Dana swap and the OD changeover, I only want to do it once.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: 76dodgeboy]
#1499316
09/10/13 04:07 PM
09/10/13 04:07 PM
Polarapete
Graham, WA
Yes, I read the response. So the 518 is a 727 with OD extension housing? If that is the case is there a number on the case I should look for from all the core transmissions laying on the ground at the local pick-n-pull? There have been a lot of transmissions made in the last twenty years and a lot of them look the same to the untrained eye. I don't pretend to be an expert. I want the simplest and strongest OD Chrysler Automatic that would not require additional electronic controls to operate. I have had painful experiences with Ford AOD transmissions (3 times in a Ford Expedition @ $3,000.00 a whack, finally rid of that POS) and I don't want a lock-up converter as that was the cause of at least one of the Ford failures.
[Re: newportrider]
#1499319
09/10/13 10:22 PM
09/10/13 10:22 PM
Posts: 8,064 Iowa
76dodgeboy
Iowa
None of my trucks are club cabs
Than they shouldn't have short tailshaft transmissions. Clubcab and crew cabs were the only ones I've ever seen with short tailshafts
[Re: 76dodgeboy]
#1499320
09/10/13 10:53 PM
09/10/13 10:53 PM
Posts: 4,576 Sarcoxie, MO, USA
MoPar Jamie
Sarcoxie, MO, USA
904s were ALL short tailshafts. The long tail in the 87 is probably a 727 because the 500 didnt come out until '88 and the 518 until '90.
- MoPar Jamie
1972 Fury III 4dr 1986 D-150 LWB Royal SE
[Re: 70Cuda383]
#1499326
09/12/13 07:58 PM
09/12/13 07:58 PM
Posts: 1,288 P.E.I. eastern Canada
newportrider
Gonna be hard to swap trans and axle without crawling under the truck!!
Wellll at 53 I'm finding less desire to get underneath even to measure the length of the trans!!! lol
