1988 Ram transmission? #1499307
09/09/13 08:39 PM
09/09/13 08:39 PM
P.E.I. eastern Canada
N
newportrider Offline OP
N
What trans is in a 88 Ram 318? Can I put any thing else in? Mine is getting bad and will be looking to replace it.
Re: 1988 Ram transmission? [Re: newportrider] #1499308
09/09/13 08:51 PM
09/09/13 08:51 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Auto = 904 727
2x stick OD833 NP 435
4x 727 if auto
NP435 if a stick
I am truckless..
Re: 1988 Ram transmission? [Re: 340SHORTY] #1499309
09/09/13 09:09 PM
09/09/13 09:09 PM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
You can put a 518 in there!
Fairly simple instal with minor fabrication, or donor parts.
Plus side is you get the overdrive, and lockup features (if you use a lockup 518).
Down side is you have to do some driveshaft mods.
But that overdrive really helps if you do much driving over 45mph.
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
Re: 1988 Ram transmission? [Re: hp383] #1499310
09/09/13 10:20 PM
09/09/13 10:20 PM
N
N
Ok,so theres nothing special because its fuel injected. I have a 727 out but I also have 904 still in an 89 now that I know they are the same.
Re: 1988 Ram transmission? [Re: newportrider] #1499311
09/09/13 10:48 PM
09/09/13 10:48 PM
State of Confusion
hp383 Offline
hp383  Offline
State of Confusion
Drive shafts will be different between 727 & 904. Both the slip yoke at the trans and overall length.
Re: 1988 Ram transmission? [Re: hp383] #1499312
09/10/13 07:00 AM
09/10/13 07:00 AM
N
N
have an 87 with a 904 short tailshaft, 86 with a 904 long tailshaft and a 89 with a 904 short shaft these trucks are all rusty but running I just hate to take them apart.LOL The only difference I seen under the truck was the electrical plug on the speedo cable right at the trans.
Re: 1988 Ram transmission? [Re: newportrider] #1499313
09/10/13 09:37 AM
09/10/13 09:37 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
So your 87 and 89 are Clubcabs?
Re: 1988 Ram transmission? [Re: 76dodgeboy] #1499314
09/10/13 01:33 PM
09/10/13 01:33 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
My '87 with 318 2 barrel has a 727 followed by a 8.25 diff. I have a narrowed Dana 60 I am going to install and will replace the 727 with a small block OD. I want one that is non-lockup and manually controlled OD (dash switch). My question is what trans would be best and how do I identify it? I know I will need to shorten the drive shaft with the Dana swap and the OD changeover, I only want to do it once.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: 1988 Ram transmission? [Re: Polarapete] #1499315
09/10/13 02:22 PM
09/10/13 02:22 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
The first 518. Did you read hp's response?
Re: 1988 Ram transmission? [Re: 76dodgeboy] #1499316
09/10/13 04:07 PM
09/10/13 04:07 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
Yes, I read the response. So the 518 is a 727 with OD extension housing? If that is the case is there a number on the case I should look for from all the core transmissions laying on the ground at the local pick-n-pull? There have been a lot of transmissions made in the last twenty years and a lot of them look the same to the untrained eye. I don't pretend to be an expert. I want the simplest and strongest OD Chrysler Automatic that would not require additional electronic controls to operate. I have had painful experiences with Ford AOD transmissions (3 times in a Ford Expedition @ $3,000.00 a whack, finally rid of that POS) and I don't want a lock-up converter as that was the cause of at least one of the Ford failures.
2008 Honda Element
Re: 1988 Ram transmission? [Re: Polarapete] #1499317
09/10/13 04:31 PM
09/10/13 04:31 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
518 is behind the Cummins. You can make just about any trans strong enough
Re: 1988 Ram transmission? [Re: 76dodgeboy] #1499318
09/10/13 08:32 PM
09/10/13 08:32 PM
N
N
None of my trucks are club cabs
Re: 1988 Ram transmission? [Re: newportrider] #1499319
09/10/13 10:22 PM
09/10/13 10:22 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Than they shouldn't have short tailshaft transmissions. Clubcab and crew cabs were the only ones I've ever seen with short tailshafts
Re: 1988 Ram transmission? [Re: 76dodgeboy] #1499320
09/10/13 10:53 PM
09/10/13 10:53 PM
Sarcoxie, MO, USA
MoPar Jamie Offline
MoPar Jamie  Offline
Sarcoxie, MO, USA
904s were ALL short tailshafts. The long tail in the 87 is probably a 727 because the 500 didnt come out until '88 and the 518 until '90.
- MoPar Jamie
1972 Fury III 4dr
1986 D-150 LWB Royal SE
Re: 1988 Ram transmission? [Re: MoPar Jamie] #1499321
09/11/13 12:05 AM
09/11/13 12:05 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Not really short tailshaft when that's the only length made
Re: 1988 Ram transmission? [Re: 76dodgeboy] #1499322
09/11/13 02:29 AM
09/11/13 02:29 AM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
Thank you for the chart! Now that is some useful information.
2008 Honda Element
Re: 1988 Ram transmission? [Re: Polarapete] #1499323
09/11/13 09:32 PM
09/11/13 09:32 PM
N
N
That's a cool chart. I haven't had time to measure them yet,just did a visual from under the truck some didn't stick out past the cross member and some did. I didn't even look at the bolt pattern on the trans base. Its been raining and I ain't crawling under no truck!
Re: 1988 Ram transmission? [Re: newportrider] #1499324
09/11/13 10:00 PM
09/11/13 10:00 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Gonna be hard to swap trans and axle without crawling under the truck!!
**Photobucket sucks**
Re: 1988 Ram transmission? [Re: 70Cuda383] #1499325
09/11/13 10:47 PM
09/11/13 10:47 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Here's one to help Id the tranny better
Re: 1988 Ram transmission? [Re: 70Cuda383] #1499326
09/12/13 07:58 PM
09/12/13 07:58 PM
N
N
Wellll at 53 I'm finding less desire to get underneath even to measure the length of the trans!!! lol
