Carb linkage #1498918
09/09/13 12:19 PM
09/09/13 12:19 PM
mississippi
bentwheel43 Offline OP
mississippi
Dose anyone use a 1 to 1 linkage to make them open at the same time for a Holley for dragracing.
Section 8 Racing We are nuts about racing.
Re: Carb linkage [Re: bentwheel43] #1498919
09/09/13 02:15 PM
09/09/13 02:15 PM
PA
70HemiGTX Offline
70HemiGTX  Offline
PA
Do you mean primaries and secondaries or dual carbs?
Re: Carb linkage [Re: bentwheel43] #1498920
09/09/13 02:44 PM
09/09/13 02:44 PM
mississippi
mississippi
Its the linkage that's hooked the 2 barrel in front to the back barrels on a 850 holley.Just a small linkage bar between the 4 barrel.
Re: Carb linkage [Re: bentwheel43] #1498921
09/09/13 02:53 PM
09/09/13 02:53 PM
mississippi
mississippi
The small bar is bent and I had to drill the bottom hole a little (of the 2 holes) to put it on,that makes them open at the same time.1 to 1
Re: Carb linkage [Re: bentwheel43] #1498922
09/09/13 03:51 PM
09/09/13 03:51 PM
PA
70HemiGTX Offline
70HemiGTX  Offline
PA
Mine are different. I have 660's on my car. They have a completely different linkage set-up.
