1969 440 warranty block
#1498410
09/08/13 05:52 PM
09/08/13 05:52 PM
Posts: 466 Keminmaa
ArcticCuda
Keminmaa
Are pads always this empty?
1970 Plymouth GTX 440-6 1970 Plymouth PPR Cuda 489-4 1971 Plymouth Duster Bad Romance 408-W5 1970 Plymouth Fury III Coupe 383-4
Re: 1969 440 warranty block
[Re: Mr D21]
#1498414
09/08/13 09:44 PM
09/08/13 09:44 PM
Posts: 11,836 Florida
mopar346
Let me tell ya about fat chicks!
I have seen a lot of blocks with mill marks like that, not aggressive enough in my opinion to be DA marks.
Have no idea, on the original question.
EDIT: Never mind, I thought you were talking about the top machined area, not the VIN pad.
Careful, your character's showing!
[Re: Mr D21]
#1498415
09/08/13 11:26 PM
09/08/13 11:26 PM
Posts: 21,501 N.E. OHIO, USA
A12
N.E. OHIO, USA
sure does look like DA grinder marks where the vin once was ??
Yep usually they only go from top left to bottom right all the way across the VIN pad and no machine marks go from top right to bottom left like in the middle of that VIN pad IMO too
[Re: ArcticCuda]
#1498417
09/09/13 07:00 PM
09/09/13 07:00 PM
Posts: 1,028 NB, Canada
moparfan53
NB, Canada
I have been told that usually there is an "S", for "service replacement", as shown below. The engine below had a blank vin pad but I don't have a pic of it.
[Re: cudaman1969]
#1498418
09/10/13 11:12 AM
09/10/13 11:12 AM
Posts: 74,979 U.S.S.A.
JohnRR
U.S.S.A.
You might have an over the counter block. My warranty block still had the markings on the pad but none on the vin pad, it also has a blue plate attached to the pass. side freeze plug boss with a steel rivet.
Do you realize that anyone counter walk up to the parts counter and PURCHASE the short block assembly that you are calling a warranty block? It would be stamped the same way AND have that little blue tag ...
Warranty block is as misused/abused a term as RADIO DELETE
[Re: ArcticCuda]
#1498420
09/10/13 04:13 PM
09/10/13 04:13 PM
Posts: 25,757 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Since a new replacement block was never "built" there wouldn't be any "build" data stamped on it.
[Re: A12]
#1498421
09/10/13 04:25 PM
09/10/13 04:25 PM
Posts: 4,231 State of retirement
52savoy
State of retirement
I've seen pads with distinct mill marks and some that aren't visable at all. To say "they go from top left to bottom right" imo is misleading It depends on where the mill operator starts his cut, mill speed, cutter depth and it's condition.
IMO, on trying to decide if a pad has been tampered with, it's the size of the mill marks. They give an idea of the cutter diameter that Chrysler used.. I've personally seen them all over the place
[Re: 52savoy]
#1498422
09/10/13 05:18 PM
09/10/13 05:18 PM
A12
N.E. OHIO, USA
Why wouldn't the VIN pad be set up to be machined the exact same way everytime? They were not done by a hand grinder (like that looks like ) They produced in one plant at least a thousand cars a day so why would they not be done with a fixed milling process?
[Re: fastmark]
#1498426
09/10/13 07:29 PM
09/10/13 07:29 PM
A12
N.E. OHIO, USA
If you compared 100, 1969 440 blocks (which were all machined at the Trenton Michigan engine plant), the VIN pad should look pretty much the same. They consistantly used a certain diameter cutter to machine the pad. I don't think this VIN pad has been tampered with other than a little Scotch Brite disc to clean it off.
I agree. A hand grinder would not look that good. It could just be an end mill with a little wore spot on it to make a mark. This crowd suspects fraud in every post>
I'm not suspecting fraud, just that the marks don't look like they were original milling marks. There is no way that VIN pad had any numbers stamped on it and no way were they ground off even if there were any there in the first place. Look closely at the top angled part of the VIN pad, it's as originally milled and not any wider or lower. Not fraud but not original factory marks either.
