Need help identifying a rod coming off the carburetor. #1498305
09/08/13 04:04 PM
09/08/13 04:04 PM
Mud Pig Offline OP
Mud Pig  Offline OP
Hey guys,
It looks as though a rod that goes from my 2 bbl carburetor and connects to the upper intake manifold has snapped off. It's on the passenger side. I'm a little at a loss for knowing what to call it so I can order the part. It looks as though its part of the manual choke. Is it a choke cable?
Mp
Re: Need help identifying a rod coming off the carburetor. [Re: Mud Pig] #1498306
09/08/13 04:58 PM
09/08/13 04:58 PM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
Something like that?
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
Re: Need help identifying a rod coming off the carburetor. [Re: hp383] #1498307
09/08/13 05:00 PM
09/08/13 05:00 PM
State of Confusion
hp383 Offline
hp383  Offline
State of Confusion
It will typically come as an assembly with the choke spring assembled part.
Re: Need help identifying a rod coming off the carburetor. [Re: hp383] #1498308
09/08/13 10:18 PM
09/08/13 10:18 PM
Mud Pig Offline OP
Mud Pig  Offline OP
That's it, now what do I tell the Summit salesguy over the phone so I get the right part?
Re: Need help identifying a rod coming off the carburetor. [Re: Mud Pig] #1498309
09/08/13 11:09 PM
09/08/13 11:09 PM
State of Confusion
hp383 Offline
hp383  Offline
State of Confusion
Not sure summit will have it. It may be a parts store or dealer item
I just did a Google search for Mopar choke spring.
Re: Need help identifying a rod coming off the carburetor. [Re: Mud Pig] #1498310
09/08/13 11:35 PM
09/08/13 11:35 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
1984 DODGE D150 PICKUP 5.2L 318cid V8 : Fuel/Air : Carburetor Choke Thermostat Price Alternate
No parts for vehicles in selected markets.
STANDARD MOTOR PRODUCTS Part # CV171
Choke Thermostat 2 BBL,CARTER & HOLLY EQPD CANADA TO 1/16/84 [Wholesaler Closeout -- 30 Day Warranty] (Only 8 Remaining)
* Stocked in outlying warehouse--shipping delayed up to 1 business day
$4.94
BWD/NIEHOFF Part # TH194
CARTER EQPD - w/o ELEC CHOKE [Wholesaler Closeout -- 30 Day Warranty] (Only 2 Remaining)
$6.43
BWD/NIEHOFF Part # TH255
Choke Thermostat HOLLEY EQPD [Wholesaler Closeout -- 30 Day Warranty] (Only 1 Remaining)
$7.44
AIRTEX / WELLS Part # 2C1147 {#4287004, E6156}
From 1/84, C-2
Carb. R40172, R40173; Exc. Canada
$9.92
AIRTEX / WELLS Part # 2C1117 {#4095339, E682}
Carb. R40172-1, R40214, R40216, R40221, R40222; Exc. Canada
$20.99
STANDARD MOTOR PRODUCTS Part # CV189 {#4095339} Remote Choke Thermostat; Electric Assist: Yes; Chrysler
Choke Thermostat 2 BBL,CARTER EQPD - US HOLLEY EQPD - CAL
Re: Need help identifying a rod coming off the carburetor. [Re: 76dodgeboy] #1498311
09/08/13 11:42 PM
09/08/13 11:42 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Re: Need help identifying a rod coming off the carburetor. [Re: 76dodgeboy] #1498312
09/09/13 03:14 PM
09/09/13 03:14 PM
Mud Pig Offline OP
Mud Pig  Offline OP
Thanks, going to order the part tonight. I really appreciate the help.
Do you happen to know what size yolk I have on my 1976 warlock, with 318 and 727 transmission? I need to order some u-joints and I'm seeing 2 5/8's and 2 1/8's yoke sizes for the u-joints.
Re: Need help identifying a rod coming off the carburetor. [Re: Mud Pig] #1498313
09/09/13 08:57 PM
09/09/13 08:57 PM
State of Confusion
hp383 Offline
hp383  Offline
State of Confusion
You wont know until you measure them, it could have either. Might even find a conversion U-joint on one end.
Re: Need help identifying a rod coming off the carburetor. [Re: hp383] #1498314
09/09/13 09:01 PM
09/09/13 09:01 PM
State of Confusion
hp383 Offline
hp383  Offline
State of Confusion
I keep this link saved in my bookmarks.
It comes in really handy!
http://www.actionmachineinc.com/ujointmeasuringguide.aspx
And if you end up with a conversion joint:
http://www.theujointstore.com/cou.html
http://www.moparts.org/Tech/Archive/shaft/4.html
