Re: 68 Dart GT convertible
[Re: burdar]
#1497845
09/22/13 11:47 PM
09/22/13 11:47 PM
Posts: 7,367 Iowa
burdar
Owen's Dad
Owen's Dad
Iowa
[Re: burdar]
#1497846
10/06/13 12:16 AM
10/06/13 12:16 AM
Posts: 7,367 Iowa
burdar
Owen's Dad
Owen's Dad
Iowa
I picked up the zinc fasteners yesterday and I'm not happy. When I picked them up, the guy said "These are going to have a little yellowish look to them because our solution is stronger. It resists a 100 hour salt spray vs the normal 40 hour spray." When I got home, I remembered that I had gotten a call that morning confirming I wanted everything yellow zinc plated. I said NO, I want them silver zinc plated. They said "OK, no problem, I thought you wanted them yellow." I think everything was already in the other tank when he called. He probably pulled them out right way after talking to me but the color had already started to change. Some things will be OK. I'm not going back stock with this thing anyway...but some things in the engine comp are going to look like crap next to other things I have planned. I sorted everything out today so I didn't forget where anything goes and I'll deal with the engine comp stuff later. I don't think they were in the yellow tank long but you can really tell the difference when you hold a silver zinc part up to them.
[Re: burdar]
#1497849
10/06/13 12:56 AM
10/06/13 12:56 AM
Posts: 7,367 Iowa
burdar
Owen's Dad
Owen's Dad
Iowa
[Re: burdar]
#1497850
10/06/13 09:12 PM
10/06/13 09:12 PM
Posts: 7,367 Iowa
burdar
Owen's Dad
Owen's Dad
Iowa
Here's the engine that's going in the Dart. As you can tell, it has been sitting for awhile. I think I pulled it out of my Cordoba in 06. It's a 360 MP short block(roller block)...the 10-1 compression version. It has home ported 360 heads with 1.88in 1.60ex valves. My Cordoba ran 12.70's with this engine. It's going to come apart for all new gaskets and to make sure everything still looks OK. It has very few miles on it so I hope it only needs gaskets. The trans is a 904 that I built in 98. It has a 10" 3500 stall convertor and a TransGo TF-2 shift kit. I started to mock up the new parts. I'm going to get everything fitting before I tear the engine apart. It looks like if I run a thermoquad, I'm going to have to make some kickdown linkage extensions and extend the throttle bracket. If I run a square bore carb, that will get rid the the adapter and lower things a little. There are already two valve cover gaskets on each side and covers are still very close to the intake. I think I'm going to look into those spacers I saw advertised on here. I don't want to grind on the valve covers or the intake. The pulleys are an underdrive version. I plan on running relays under the battery tray for the headlights and make sure the cooling system is designed properly.
[Re: Rhinodart]
#1497853
10/16/13 01:03 PM
10/16/13 01:03 PM
Posts: 7,367 Iowa
burdar
Owen's Dad
Owen's Dad
Iowa
[Re: burdar]
#1497854
10/28/13 11:06 AM
10/28/13 11:06 AM
Posts: 7,367 Iowa
burdar
Owen's Dad
Owen's Dad
Iowa
I got done rebuilding one of the horns yesterday. Only one of them worked when I tested them. I used Mike Ross' post on how to rebuild a Prestolite horn for reference. It was basically the same procedure rebuilding(just cleaning really)my Sparton horn. First I drilled the heads off of all six rivets and separated the two halves. Once they were apart I drilled and tapped the rivets for 8-32 allen head screws. This wasn't fun because the rivets wanted to spin inside the cone housing. I had to remove them and glue them in the housing. I made two new gaskets from a Christmas box my wife had been saving....don't tell her. I used some C-clamps to hold the horn together while testing. Just like Mike said, all that was needed to get it working again was to sand the contacts. Once it was screwed back together I tested it again just to make sure the center piece hadn't shifted. It still worked so it was ready for paint. Since I'm not going back stock with the car I didn't bother sanding on the allen screws to make them look more like rivets. I'm going to use allen head fasteners on the engine so it will all tie together. This picture was taken right after I sprayed it. It dried slightly less glossy then what it looks like in this picture. I also cleaned up the shifter pivot bracket that bolts to the trans. It cleaned up nicely. I still have to buy a new bushing...the original was in two pieces.
[Re: burdar]
#1497855
11/16/13 10:07 PM
11/16/13 10:07 PM
Posts: 7,367 Iowa
burdar
Owen's Dad
Owen's Dad
Iowa
