Re: 5.7 Hemi Forged Crank?
[Re: dart69bigblock]
#1497796
09/07/13 07:54 PM
09/07/13 07:54 PM
Posts: 1,130 Dayton, Ohio
wldtm
Dayton, Ohio
6.1 crank works in the 5.7,you can find those for $200 used in good condition. The reluctor is different for the crank sensor.
I have one for sale, but it needs to be turned down
justin
Interested in having you car wired? Drag car, street car, EFI swap?
PM for details
#1497800
09/08/13 09:26 AM
09/08/13 09:26 AM
Posts: 10,016 Frostbitefalls MN (Rocky&Bullw...
gregsdart
How about a new 4.050 crank?About $800, I think Molner makes some with 2.00 rod journals so you can use SBC rods, shelf pistons. Granted, it is more expensive, but if the rods are cheaper (SBC Hbeams) it might soften the cost some. There are a number of stroker pistons out there for some good 5.7 combos. I found a 3.888 stroke crank at Lofgrens at a good price, plus I bought the rods out of his Drag Pac motor which will give me about a 6.3 Hemi. I am not sure if he has any left, though.
[Re: gregsdart]
#1497801
09/08/13 11:03 AM
09/08/13 11:03 AM
Posts: 3,635 Oakland, MI
dizuster
Oakland, MI
Depends how much power you want to make, but the 6.1L crank is a good choice. I've talked to a few high HP engine builders that are using them (HHP,BES,etc...). I told them that I wanted to make 1000hp and they told me no problem on a boosted 6.1L stock crank.
I'm just starting going down this road. 6.1L crank, 03~08 block/heads, stock rockers, stock non-MDS lifters, and there are some new non-mopar drag pack intakes being cast.
80mm turbo should be able to make 1000hp pretty easy/reliably.
[Re: STEFF]
#1497803
09/09/13 02:48 AM
09/09/13 02:48 AM
Posts: 4,302 Nebraska
72Swinger
Nebraska
SO the 6.1 cranks are drilled same as the 5.7's?
Mopar to the bone!!!
