change out and lost the gages and it runs on about 1-2 seconds while it revs slightly. Also during run on at least the amp gage and the oil pressure start to move. Only the back lights work on the dash with the turn signal indicators. It did a couple of times not want to idle and had to apply a little throttle to start. That hasn't happened recently though. Saw a recommendation online for a '97 Dakota to check the IOD (ignition off draw) fuse at the junction block. Cannot find in my 2000 Dak. 3.9 liter auto, 2wd. Any thoughts or suggestions? Thank you It has good continuity to ground. And did try old battery and pulled terminals off battery for about 10 minutes.
